NeoPixels Matrix:Snake Game
Published
Introduction: NeoPixels Matrix:Snake Game
About: ElecFreaks is an open design house founded in March 2011. Our goal is to create rapid prototypes and give small-batch manufacture solution for makers and startups. With over 50% staff as engineers and expand...
Do you still remember snake game we played on our game box or mobile during our childhood? Today we are going to learn how to make a snake game with 8*8 NeoPixels Matrix. We choose Arduino uno as the control center and Joystick breakout module to control the snake.
Step 1: Components List:
Step 2: Hardware Connection
Connect NeoPixels to pin D2.
"X" on Joystick breakout module connect pin A0 on Arduino UNO board, "Y" connect pin A1, "K" connect pin A2.
Step 3: Programming
<span style="color: black; font-family: Arial; font-size: 12pt;">P#include <Adafruit_NeoPixel.h>
#define PIN 2           //Output Pin
#define MAX_LED 64       //Quantity of bead
uint32_t c;
int a = 0 , number;
unsigned char huan = 0, ci = 0;
unsigned char  u = 40; //The font size of word group
unsigned char x = 0;
unsigned char Colour[3];
unsigned char go[] = {2, 3, 4, 5, 9, 14, 17, 20, 22, 26, 27, 29, 34, 35, 36, 37, 41, 46, 49, 54, 58, 59, 60, 61}; //24
unsigned char light[8][8] = {
  {0, 1, 2, 3, 4, 5, 6, 7},
  {15, 14, 13, 12, 11, 10, 9, 8},
  {16, 17, 18, 19, 20, 21, 22, 23},
  {31, 30, 29, 28, 27, 26, 25, 24},
  {32, 33, 34, 35, 36, 37, 38, 39},
  {47, 46, 45, 44, 43, 42, 41, 40},
  {48, 49, 50, 51, 52, 53, 54, 55},
  {63, 62, 61, 60, 59, 58, 57, 56},
unsigned char character[][8] =  //Set the word to be sent
  {0, 1, 1, 1, 1, 1, 0, 0},
  {0, 1, 0, 0, 0, 1, 0, 0}, // 0
  {0, 0, 0, 0, 0, 0, 0, 0},
  {0, 0, 0, 0, 0, 0, 0, 0}, // 1
  {0, 1, 0, 1, 1, 1, 0, 0},
  {0, 1, 0, 1, 0, 1, 0, 0}, // 2
  {0, 1, 1, 1, 0, 1, 0, 0},
  {0, 1, 0, 1, 0, 1, 0, 0}, // 3
  {0, 1, 1, 1, 0, 0, 0, 0},
  {0, 0, 0, 1, 0, 0, 0, 0}, // 4
  {0, 1, 0, 1, 0, 1, 0, 0}, // 5
  {0, 1, 0, 1, 0, 1, 0, 0}, // 6
  {0, 1, 0, 0, 0, 0, 0, 0},
  {0, 1, 0, 0, 0, 0, 0, 0}, // 7
  {0, 1, 0, 1, 0, 1, 0, 0}, // 8
  {0, 1, 0, 1, 0, 1, 0, 0}, // 9
unsigned char displayscore [8][8];
int speedS = 400;                                                         // Initial speed of snake
int score;                                                              // Game score
int xValue;                                                             // JoyStick-X
int yValue;                                                             // JoyStick-Y
int zValue;                                                             // JoyStick-Z
int FX, FY;                                                             // Coordinate of food
int SX, SY;                                                             // Coordinate of snake head
int KEY, K;
int Enabled;                                                            // Enable to restart game
char sx[64] ;                                                     //Coordinate of snake body
char sy[64];
Adafruit_NeoPixel strip = Adafruit_NeoPixel( MAX_LED, PIN, NEO_RGB + NEO_KHZ800 );
void RANDOM() {
A:
  FX = random(0, 7);
  FY = random(0, 7);
  for (int i = 0; i < 3 + score; i++)          //Prevent food display on snake body
    if ( FX == sx[i] && FY == sy[i])
      goto A;
void myDelay( unsigned int Time) {                             // During the delay period of snake movement, we have to do something like food glitter and read the direction of Joystick
  for (int t = 1; t <= Time; t++)
    joyStick();
    delay(1);                                     //Read the direction of Joystick
void joyStick() {
  xValue = analogRead(A0);                             // JoyStick-X   The leftmost value is 0, the rightmost value is 1023, and the middle value is 515.
  yValue = analogRead(A1);                             // JoyStick-Y   The bottom value is 0, the top value is 1023, the middle value is 510.
  if (yValue > 950 && KEY != 5) {
    K = 8;
  else if (yValue < 50 && KEY != 8) {
    K = 5;
  else if (xValue < 50  && KEY != 6 && K != 0) {       // Before operate Joystic for the first time, you can't move snake to the left direction.
    K = 4;
  else if (xValue > 950 && KEY != 4) {
    K = 6;
// Here you can compare whether the direction of keypad is opposite to the snake move direction. If it is opposite, then give up the keypad.
void gameover() {                                      // Once Gameover program stopped, press the central button to restart the game.
  unsigned char value, y;
  Colour[0] = random(3 , 18); // Set color.Parameter is R G B, range 0-255.
  Colour[1] = random(3, 18);
  Colour[2] = random(3, 18);
  c = strip.Color(Colour[1], Colour[0], Colour[2]);
  value = score / 10;
  value = value * 4;
  y = 0;
  for (number = value; number < value + 4; number++)
    for (unsigned char vertical = 0; vertical < 8; vertical++)
      displayscore[y][vertical] = character[number][vertical];
    y++;
  value = score % 10;
  value = value * 4;
    y++;
  for (unsigned char horizontal = 0; horizontal < 8; horizontal++)
      if (displayscore[horizontal][vertical] == 1) //Judge whether the light is on.
        strip.setPixelColor(light[horizontal][vertical],  c);
      else
        strip.setPixelColor(light[horizontal][vertical],  0);
  strip.show();//Send data
  delay(5000);
  K = 0;                  // Reset Joystick direction
  sx[0] = 2;
  sx[1] = 1;
  sx[2] = 0;
  sy[0] = 1;
  sy[1] = 1;
  sy[2] = 1;               // Reset snake coordinate
  score = 0;              // Reset game score
  speedS = 400;                                                         // The initial speed of snake
void setup() {
  Serial.begin(9600);
  // Initialize library
  strip.begin();
  // Send data. Default the color of each point as 0. So every point is not illuminated at the beginning.
  strip.show();
  K = 0;                  // Reset the direction of Joystick
  sx[0] = 2;
  sx[1] = 1;
  sx[2] = 0;
  sy[0] = 1;
  sy[1] = 1;
  c = strip.Color(Colour[1], Colour[0], Colour[2]); //Green  Red Blue // Set color
  for (number = 0; number < 24; number++)
    strip.setPixelColor(go[number],  c);
  strip.show();// Send data
  delay(2000);
  RANDOM();     //Produce food
void mobile()
  KEY = K;                                      //Every movement of snake makes the direction change for once.
  if (KEY == 8)                                 // Snake upward movement
    for (int i = 2 +  score; i > 0; i--)
      sx[i] = sx[i - 1];
      sy[i] = sy[i - 1];
    sy[0] = sy[0] - 1;
    if (sy[0] < 0)                               // Go beyond the border and continue on the other side
      sy[0] = 7;
  else if (KEY == 5)                            // Snake downward movement
      sx[i] = sx[i - 1];
      sy[i] = sy[i - 1];
    sy[0] = sy[0] + 1;
    if (sy[0] > 7)                               // Go beyond the border and continue on the other side
      sy[0] = 0;
  else if (KEY == 4)                            // Snake left movement
      sx[i] = sx[i - 1];
      sy[i] = sy[i - 1];
    sx[0] = sx[0] - 1;
    if (sx[0] < 0)                               // Go beyond the border and continue on the other side
      sx[0] = 7;
  else if (KEY == 6)                            // Snake right movement
      sx[i] = sx[i - 1];
      sy[i] = sy[i - 1];
    sx[0] = sx[0] + 1;
    if (sx[0] > 7)                               // Go beyond the border and continue on the other side
      sx[0] = 0;
  // Move snake body with button
void displays()
  for (number = 0; number < 64; number++)   //Clear the screen
    strip.setPixelColor(number,  0);
  strip.show();
  Colour[0] = 40; // Set color. Parameter is R G B, range 0-255.
  Colour[1] = 0;
  Colour[2] = 0;
  x = light[FX][FY];                                              //Display food
  strip.setPixelColor(x, c);
  Colour[0] = random(3 , 18); // Set color. Parameter is R G B, range 0-255.
  for (int i = 2 +  score; i > 0; i--)                   //Display snake body
    x = light[sx[i]][sy[i]];
  Colour[0] = 0; // Set color. Parameter is R G B, range 0-255.
  Colour[1] = 40;
  Colour[2] = 0;
  x = light[sx[0]][sy[0]];                                        //Display snake head
void loop() {
  mobile();
  myDelay(speedS);                                // Within() is delay time.
  displays();
  SX = sx[0];
  SY = sy[0];
  // Get coordinate of snake head
  for (int i = 1; i <= 2 + score; i++)
    if ( SX == sx[i] && SY == sy[i])
      gameover();
  // Judge whether snake head touched its body. If touched, then forward to GameOver.
  if (SY == FY && SX == FX)
    RANDOM();
    score ++;
    Colour[1] = 0;
    Colour[2] = 0;
    if ( !(score % 5)) {                      // Accerlerate snake speed according to the score. Every 5 foods eaten, accerlerate 100ms.
      speedS = speedS - 50;
      if (speedS < 150)                         // The bottom limit is 200ms. If speed lower than 200ms, the speed stays 200ms.
        speedS = 150;
  // Judge whether food are eaten. If snake ate food, then plus scores and regenerate food randomly.
Experiment Result
Step 4: Experiment Result
    • Oil Contest
      Oil Contest
    • Planter Challenge
      Planter Challenge
    • Clocks Contest
      Clocks Contest
