Previous Instructable >> Fabric Bend Sensor
Using neoprene, Velostat, conductive thread and stretch conductive fabric to sew your own fabric bend sensor. The sensor actually reacts (decreases in resistance) to pressure, not specifically to bend. But because it is sandwiched between two layers of neoprene, pressure is exerted while bending. Allowing one to measure bend (angle) via pressure.
To make the sensor fully fabric one can use EeonTex conductive textile (www.eeonyx.com) instead of the plastic Velostat. Eeonyx normally only manufacture and sells its coated fabrics in minimum amounts of 100yds, but 7x10 inch (17.8x25.4 cm) samples are available free of charge and larger samples of 1 to 5 yards for a minimum fee per yard.
VIDEO
To prove the competitiveness of this sensor vs. a commercial bend sensor I made a short video in which Sheep demonstrates their similarities.
Remove these ads by
Signing UpStep 1Materials and Tools
Velostat is the brand name for the plastic bags in which sensitive electronic components are packaged. Also called anti-static, ex-static, carbon based plastic& (So you can also cut up one of these black plastic bags. But caution! Not all of them work!)
- Neoprene 1.5 mm thick HS quality from www.sedochemicals.com
- Velostat by 3M from http://www.lessemf.com/plastic.html
- Conductive thread from http://www.lessemf.com/fabric.html
- Stretch conductive fabric from http://www.lessemf.com/fabric.html
- Fusible interfacing from local fabric store
- Regular sewing thread from local fabric store
TOOLS:
- Pen and paper
- Fabric scissors
- Iron
- Sewing needle
- Possibly pliers for pulling needle through neoprene
I am trying to build a flex sensing glove to control a robotic hand that I am building currently. So any ideas would be greatly appreciated.
Greath idea and Super instructables.
Have you some Ideas where is possible to find in Europe some sheets of EeonTex?
I'm working to construct some of this for one subject in my University in Italy, also connected to Arduino.
Thnx
Nino
Great demo and I love the display on your computer. I am interested in how you created the display is this a home made interface or something commercial??
Regards,
>> http://www.instructables.com/id/Fabric_bend_sensor/step8/Software-Visualization/
basically i'm using the free programming environment Processing to write a basic graph application and the code for that application can be downloaded from the link above.
to get clearer readings try a low pass filter - insert a capacitor of 4,7uF - 10+uF parallel to your pull-up resistor >>
http://en.wikipedia.org/wiki/Low-pass_filter
http://www.hookloopoutlet.com/neoprene-sheets.html
I sent inquiry to http://www.sedochemicals.com/, but have not got reply yet. It seems to me since the company is in Germany and I am in US, it might be impossible for me to get 2-3 sheets from them - is it true according to your experience? I have checked local stores and have not got satisfactory neoprene so far. Neoprene rubber seems not good enough.
