Nerf CS-35 Sawn Off Mod by Amigobot
this is a poor instructable of how to make your raider a little more cooler by relocating the cocking mechanism.
I also did this mod because unless you've modded the barrel to be air tight with the firing barrel you're gonna loose distance.
 i appologise for the lack of descriptive photos, but it's a reasonably simple idea an im sure you can figure out anything i've been vague on.
you'll need the following:
hacksaw
superglue
craft knife
a CS-6 stock
the attachable flick up sight (i got mine from the cs6)
NOTE: please see additional photo if you're confused about the last two items.
Step 1: Lets do this! cutting this bad boy short
ok so unscrew the gun an open it up. take out the extended barrel (not the one the dart goes in). now look closely at my picture to see where you're going to cut. remember to cut a small section of the barrel to replace the giant one you took out , mine's about 41mm long. once you've hacked up your gun, trim any burrs with a knife and then super glue each half to its corresponding opposite (only glue the blue parts.. dont glue in the orange peices).
wow this is hard, i hope you're still following with me.
eklios says: Jan 5, 2012. 6:59 AM
thank you for this i read this and just did this mod. with one exception i used the rod it came with and put the cocking mecinism father back. but this instructable gave me the insperation and the idead it could be done. thank you
sonofstone says: May 5, 2011. 1:46 PM
no needs for apolagy's, this instructable is easy to follow when creative, it is certainly a good mod, but a little too destructive for my account, anyway, nicely done, and dont apolagize, sorry if i mis spelled anything, im from the netherlands
Amigobot (author) says: May 13, 2011. 6:50 PM
You spelled correctly, thankyou for the compliment, you are very generous.
gundamreaper7 says: May 11, 2011. 12:19 PM
nice model i liked it alot dont apolagize
sithlil says: Mar 22, 2011. 2:34 AM
does it shoot further?
MAVREV13 says: Mar 13, 2010. 4:54 PM
pritty cool it is a nice mod but needs a paint job.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
