Nerf Crossfire Mag Mod
3,146
22
11
Posted in PlayNerf
Introduction: Nerf Crossfire Mag Mod
This Instructable will hopefully teach you how to mod your Nerf Crossfire to be able to hold and use a magazine found in various other Nerf guns. Note that doing this will probably destroy your gun, however if done correctly, the gun should work but might not shoot quite as far. But who CARES! This mod will take about two days and doesn't require too many extra materials or tools.
Materials:
-Nerf Crossfire
-Plexiglass
-Hot Glue
Tools:
-Hacksaw
-File
-Hot Glue Gun
-Vice or Pliers
Step 1: Cutting
Cut out the front of the gun where the mag would go (pretty much where the pictures specify).
Step 2: Replacing the Compression Chamber
In this step you are going to have to cut open the cylinder located behind the bullet holder. You have to cut it so that it can accommodate the Nerf mag. Use the the little rod at the bottom of the bullet holder and glue it to the roof of the chamber. Put the cylinder back (but not the bullet holder) into the inside of the gun, then screw both sides back together.
Step 3: Magazine
This step will show you how to make a case for the magazine. Cut two square sheets of plexiglass 8.5 cm by 4.5 cm and another that is      2 cm by 6.5 cm, glue these sheets together into sort of a cube onto the circle where  the bullet holder used to be. These measurements should be big enough to allow room for the magazine, but if not, you can just improvise.
    • Flowers Challenge
      Flowers Challenge
    • Slow Cooker Challenge
    11 Comments
    Neat, however the air seal has to be crap now. If you add a breach, this thing would be really cool
    Yeah I agree I was thinking about doing something like this even before I saw this instructable but I decided not to because a breech would be too complicated (for me anyways) and I don't use them except as backups so it wasn't really necessary. I wish the author posted a firing video
    Not as far as it would normally, probably 2/3 the usual distance
    I was gonna make this mod, but I gave away my Crossfires to a freind
    this is sick
    YOU LEGEND - that is the best nerf gun mod I have ever seen EPIC!!!
