Nerf Demolisher Desert M4 Carbine
PlayNerf by
Introduction: Nerf Demolisher Desert M4 Carbine
This instructable covers how to make the Nerf Demolisher to resemble the Desert M4 carbine.
Step 1: Parts & Tools
Parts & Tools Required
Nerf Demolisher.
Nerf Modulus Duel Rail Barrel Extension
3D Printed – Nerf to Picatinny Rail Mount. ( 6.5" long )
3D Printed - Nerf to Picatinny Rail Mount. ( 2.5" long )
3D Printed – Muzzle Break Barrel Extension with Sight Tower for Nerf Gun
15 shot banana magazine
Nerf Raider or Super Soaker extending shoulder stock.
Airsoft Picatinny carry handle
Most of these parts can be found listed on Ebay.
Extra Nerf rail ( salvaged from another blaster or super soaker )
Small Phillips head screw driver
Tan/Sand colored spray paint or vinyl dye.
Painters tape
Step 2: Adding the Extra Rail.
Here I've cut the rail off of a broken Super Soaker I salvaged for parts & glued it to the top of the gun behind the access door.
Notice that the seam of the rail lines up with the seam of the gun. Done properly this will allow the gun to still be disassembled for repair if necessary.
Step 3: Dissembly & Paint Prep
Here I've removed the 4 screws that hold on the pump for the rocket launcher. This allows the handle , slide & plunger to be removed.
I've also taped off the areas of the gun & barrel extension that I don't want painted.
The stock has already been painted.
Step 4: Paint
Here the parts have been painted & prepped for reassembly.
Step 5: Reassemble & Complete
Reassemble the blaster, replace the batteries & cover , rocket launcher plunger & it's handle.
The Nerf to Picatinny rail pieces slide over the original Nerf rails & tighten down with set screws.
Place the rear one & secure it first. Slide the front rail on but do not secure it.
The handle has 2 screws that both tighten down the side clamp & lock into the groves in the rail so the handle doesn't slide forward or back.
Position the handle on the two rails. You can slide the front rail forward or back until the handle screw lines up properly. Tighten the handle screws down then tighten the set screws on the rail to lock it onto the blaster.
Snap on the extendable stock.
Add the Demolisher barrel extension.
Add the Muzzle Break Barrel Extension & 15 shot banana clip.
( Optional ) add another 3.75 - 4" Nerf to Picatinny conversion rail to the front barrel extension top.
Load up your completed Nerf M4 & have some fun.
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    I usually don't like replicas of real guns as nerf, but this is just beautiful.
    I prefer more realism & detail in my blasters, though I do have a few fantasy guns. That said, I wouldn't dream of goofing off in public with this one or any of the other more realistic guns I've made. Those are restricted to my property &/or a well identified arena.
