Nerf Grenade Launcher Attachment
 by Inverted_Spectrum
Using meanbean's Nerf Hand-blaster , and a bit of ingenuity inspired from Call of Duty, I made an attachable mount for my modified Recon. I removed the attachment bit off an old Nerf attachment and used part of an Axe Deodorant Spray Can to make the mount, which works as a simple sight also. It's possible to place a flashlight too, so this is a great multifunctional attachment.
In terms of power Tests 2 and 4 has the launcher powered with two springs to add more distance when launching.  The ammo is large foam insulator for the grenade; material that is similar to stefans.
Step-By-Step coming soon!
davtheman223 says: Nov 30, 2012. 1:52 PM
this is meanbeans idea too
davtheman223 says: Nov 30, 2012. 1:29 PM
could you read the url it says instruct in it
maxomega says: Sep 6, 2011. 5:38 PM
Also, where did u get the tube from the mount?
holyfire says: Jul 27, 2011. 8:08 PM
So, ive been playing around with this idea since about last november when i saw Meanbean's 'ible. What ive been trying to figure out though is a way to fire the thing without having to turn the bottom part by hand, with something that uses a trigger instead to turn the base. Ill upload pics in the next few days of what ive been working on so far. if you have any idea, id like to hear them. Thanks
Matrix-technician says: Mar 28, 2011. 11:27 AM
Great job! I made somthing simalar using maxxem's grenade launcher as a basis for mine, it fires green nerf balls up to 30 feet.http://www.instructables.com/member/maxxxem/
Inverted_Spectrum (author) in reply to Matrix-technicianMar 28, 2011. 3:14 PM
Yeah, I saw that one too. With mine it goes to 30 feet too with my custom ammo as a grenade, and with darts it has a wide blast radius if you amp the power.
For ammo, I used foam pipe insulator (similar to the material for stefans, only bigger.)
atomiclegocreations in reply to Inverted_SpectrumJul 27, 2011. 4:48 PM
read the comment, thanks for saying how you made that grenade of yours.
atomiclegocreations says: Jul 23, 2011. 7:40 PM
any other ways to make a mount besides using body spray can parts, i mean, i plan on making a mount for my recon, but i really don't want to get some sort of deodorant or whatever. can you help?
atomiclegocreations in reply to atomiclegocreationsJul 24, 2011. 7:47 AM
now that I think of it, i could use a PVC pipe and chop off some and hot-glue that to the think that attaches to the attachment rail.
atomiclegocreations in reply to atomiclegocreationsJul 27, 2011. 4:47 PM
works. put some duct tape in for friction.
1990cujo says: Apr 22, 2011. 3:27 PM
more of a shot gun than a grenade launcher
Inverted_Spectrum (author) in reply to 1990cujoApr 24, 2011. 11:48 AM
Depends how it's used, but a shotgun seems to be a better use.
atomiclegocreations in reply to Inverted_SpectrumJul 27, 2011. 7:43 AM
with your foam grenade (by the way, how did you make or get that) in there, it looks like the grenade launcher i'm used to.
stick11 says: May 12, 2011. 12:44 AM
This is so awesome! Can't wait for step by step approch!
atomiclegocreations in reply to stick11Jul 24, 2011. 3:48 PM
I think I'm gonna try to make an 'ible for this. I mean, so many people are asking how.
kve23 says: May 25, 2011. 10:37 AM
u sould use my nerf grenades but with the pin removed.
atomiclegocreations in reply to kve23Jul 24, 2011. 10:28 AM
i can imagine that being a frag grenade for the grenade launcher. it's a great idea. I used a Lego piece to represent the keyring
kve23 says: May 25, 2011. 10:35 AM
u should use one of my nerf grenades but with the pin removed.
moocowdog says: Apr 1, 2011. 11:02 PM
how does it shoot? is it just for looks?
Lego Nerf stuff in reply to moocowdogApr 16, 2011. 7:21 PM
it shoots
Inverted_Spectrum (author) in reply to moocowdogApr 2, 2011. 7:11 PM
Follow the link placed. By using meanbean's hand-launcher, it propels an object forward (in this case, the "grenade"). The party popper is spring loaded, so by twisting the base it launches the "grenade"
I'll try to place a video file later. Can you give me a list of available video formats?
moocowdog in reply to Inverted_SpectrumApr 2, 2011. 8:20 PM
wait, do you pull the back of the launcher and let go?
username252 in reply to moocowdogApr 5, 2011. 7:27 PM
Video added. /watch how the base is being twisted; that's how it's being launched.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
