Nerf Gun Modification
In this instuctable, you will make a nerf gun mod for the NERF N-STRIKE LONGSHOT CS-6 nerf gun. It will pretty much make it shoot alot faster and farther. Its my first instructable, so bear with me. And sorry, I made the gun and then realized i should have taken pictures of the steps. The pictures will not match up with the steps, they are just there for visual effects.
Step 1You will need...
You will need...
1- 2" PVC Pipeing-9 inches
1- 2" PVC End Cap
1- 2" PVC Coupling
1- 2" by 1/2" PVC Bushing(half inch is to be threaded)
1- 3/8" Ball Valve
2- 3/8" Close Nipples(what it says on the receipt)
1- 1/2" by 3/8" Brass Pipe Bushing
1- 3/8" by 3/8" Tube to pipe converter
1- 3/8" Braded PVC Tubing( 12 inches)
PVC Cement
Teflon Tape
Strong tape( i used duct tape)
Wrenches
Bike pump or air compressor
Look at the pic on the previous page to see a picture of all ingredients.
87 comments
1-40 of 87next »
Oct 28, 2011. 2:08 PMwill7917hero says:
I've seen Nerf guns better than that,DUDE
Aug 1, 2011. 1:52 PMjumpingcat says:
Muhahahahaha!!!! I smell waffles
Mar 19, 2011. 10:40 PMsirodim90 says:
Isn't this too complicated to be nerf?
Dec 10, 2010. 5:47 PMzack247 says:
maybe a valve like those used in compressiion guage will work? it is just a button and when you press it the air is all let out instantly.
i will try this with my now broken nerf gun.
Mar 10, 2007. 9:24 AMKarim says:
That's sweet i'll if you want to make the gun more fun, stick a needle or nail through the back of the dart and push it through until it comes through the top of the dart, and then you have a hunting dart!!! I did it to my n-strike nite finder
Jun 3, 2010. 6:01 PMMorriscow says:
 i did that to my longshot
it takes a while to figure out the perfect length though
˙˙MACS RULE˙˙
(Ubuntu does too)
Jul 9, 2009. 10:41 PMSpiderdog3000 says:
Also, if one is going to use this on the field, then it seems like a bit of an unwieldy process to pump it up with a bike pump or an air compressor. Is there a way to tape the bike pump onto the gun as well? Would that work?
May 30, 2010. 11:52 PMzack247 says:
perhaps interchangable air chambers?
Dec 9, 2009. 6:28 PMMrMystery96 says:
you could have a small compressor, like one small enough to fit into a back pack, and have it connected to the fill valve. if the compressor has a lock on the head, then your good. simply use a smaller section of pvc pipe, so that your pressure builds quicker, then you essentially have an unlimited amount of air, pressure, and power! (without the pain of carrying the compressor by hand.
Jul 14, 2009. 8:49 AMSpiderdog3000 says:
Approximately how much does all this cost?
Dec 11, 2009. 3:09 PMmeat grinder says:
over 9000 pounds!
Apr 19, 2010. 6:17 AMfinmonster says:
lol
Dec 11, 2009. 4:42 PMSpiderdog3000 says:
WHAT 9000? THAT CAN'T BE RIGHT!
Feb 11, 2011. 12:34 PMbadideasrus says:
i do belive you are not familiar with the meme. then again there are-- OVER 9000!!
Jul 16, 2009. 6:11 PMSpiderdog3000 says:
Does it have to be 3/8" can it be 1/2"?
Aug 26, 2009. 7:17 PMmettaurlover says:
yes, actually, it does to fit inside the barrel. the othe way around would fit outside the barrel.
Sep 19, 2009. 7:24 PMSpiderdog3000 says:
If it's outside the barrel, does that make it better?
Sep 19, 2009. 8:22 PMmettaurlover says:
no. in fact, that makes it worse because there will always be some air that leaks on a pipe that fits around the other one if said pipe is the source, while if said pipe is the destination it doesn't lower the pressure at all.
Sep 20, 2009. 11:41 AMSpiderdog3000 says:
Well it's a good thing I didn't do that.
Sep 20, 2009. 5:05 PMmettaurlover says:
yep. anyway, gotta get back to work on my railgun minigun.
Jul 10, 2009. 11:11 AMclemsonguy1125 says:
why even use a a nerf gun
Aug 26, 2009. 7:18 PMmettaurlover says:
"brings out modded vulcan*
DON'T INSULT THE NERF. EVER.
Aug 27, 2009. 2:13 PMclemsonguy1125 says:
i mean just use a pvc barrel instead of the nerf gun shell better range
Aug 27, 2009. 7:09 PMmettaurlover says:
not necessarily. some people replace the barrel with a PVC pipe; some choose brass, and some, like me, just plug thew bleeder holes with epoxy.
Aug 10, 2009. 5:25 PMSpiderdog3000 says:
Thanks! I successfully made the mod and it works REALLY WELL.
Jul 16, 2009. 6:48 PMSpiderdog3000 says:
What should I use to seal this part? More teflon tape?
Jul 9, 2009. 10:28 PMSpiderdog3000 says:
Where would you put the gauge if you added one?
Dec 22, 2008. 12:17 AMqon duixote says:
just a reminder because I didn't see it on here, PLEASE use pressure rated pipe it's usually white with blue letters providing the rating, the gray stuff called conduit or drainage pipe isn't built to hold pressure, it'd probably hold the 20 psi but it's not worth the 20 cents you'd be saving. Make sure you pressure test the system before you go lining up the sights with the pressurized tubing next to your face. By the way Eye Protection is cool, just like on Mythbusters
Apr 8, 2009. 6:33 PMGamer917 says:
yay another mythbusters fan!
May 17, 2009. 4:47 PMdata23 says:
if ur on instructables, chances r. . . ur a mythbusters fan!
May 30, 2009. 12:20 PMxXxSubZero117 says:
And if you use texts like ur r lik Chances are you either use Myspace of text on a phone! Mythbusters is awesome!
Apr 2, 2009. 1:44 PMSpeedmite says:
So basically a potato cannon cross bred with nerf? Well in that case all I need is a smaller barrel to put on instead of the potato one. 60psi in a 1/2inch tube here I come! This should go farther than potatoes! OH! And them screamer darts would be awsome!!!!
Apr 3, 2009. 5:17 PMLordSnipe says:
just a comment, I built a similar system a while ago (last year) and I noticed that nerf darts need to "burn in", that is that the rubber head is a SLIGHTLY larger diameter than the 1/2" pvc, so you need high pressures to just use PVC pipe for a barrel. Also, try to salvage bullets,as they shoot faster with use.
Apr 7, 2009. 1:33 PMSpeedmite says:
It was just an approximation. And if you made your own darts you could make them 1/2 inch. Or you could sand the inside a lot to make it bigger.
Apr 5, 2009. 10:04 AMburgleflickle says:
I like it, but you can get more range with the sniper pistol. Maybe replacing the pvc with a soda bottle for higher psi, and some barrel modifications.
Apr 2, 2009. 4:29 PMQuiksilverRox says:
I made something like this but only out of PVC and those darts leave huge bruises. I usualy pump it to 150psi.
Aug 5, 2008. 11:42 AMPhantom5582 says:
I'm so going to do this, but I'm going to take apart a paintball gun for some parts. I want to build it into my Nerf maverick in a way where I can still use it the way it was, but I don't have to cock the piston back between shots. If I can get the slide to slam back with each shot, that would be cool as well. I think the only part of this I'm going to use is the air tank. I'm going to build two, one to pressure test and the other for the gun itself.
Sep 20, 2008. 9:52 AMCapnTac says:
You mean something like this?:
http://www.nerfhq.com/smf/index.php?topic=7345.0
(3rd picture down)
Sep 20, 2008. 11:03 AMPhantom5582 says:
Wow... That is good. That is almost what I want, but it looks like it would be the best I'll get. The only thing that is different from what I want is that I wanted the hose to exit From the base of the gun.
1-40 of 87next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:modmaster
