3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Nerf Gun Modifications.
Nerf guns are not just for kids any more. In this how-to, you will learn how to make home made darts, modfy your nerf gun, and convert a watergun to shoot nerf darts. Mod a few guns, call up the friends, and shoot each other like your 10 again!
Step 1Making Darts
Making Darts
This is the simple really. Materials are more the issue. You will need:
-Foam Backer Rod. Its found in a hardware store. It looks like the above. A big coil of foam. Try get 1/2"
- Fishing Weights. Ofcourse BB's, old nuts, anything that is small and has some weight to it will work.
-A glue gun and glue.
First, take the FBR and cut a small piece off. Use the glue gun to bore a hole in it. Now that you have a hole, drop your weight in it. Now alll you have to do is cover the hole with hot glue. Don't be afraid to lick your fingers and push the glue down for a better fit.
Repeat this for a good 50 darts and your in business.
320 comments
1-40 of 320next »
Aug 23, 2010. 12:35 AMghoru says:
another way to get some extra kick, stretch the spring that forces the piston into the barrel or replace with a stronger spring. also by using the "buzzbee toys" darts (cheaper brand) they are slightly bigger and harder darts, force them into the barrel, cock the gun pull the trigger. the dart wont come out but a nice whack on the cocking mech and these darts hurt. i got hit in the mouth and had my gums split
Dec 23, 2011. 11:43 AMFirst Knight says:
That's disgusting! What was under your gums?
Sep 23, 2010. 5:22 PMtifrankvl says:
Sorry, but stretching the spring just weakens it.
Dec 11, 2011. 3:13 PMWilne99 says:
you could also just cut the top off of a nerf bullet.....
Dec 6, 2011. 2:44 PMcioaonk says:
Nerf Haven is like the Hardcore instuctables
Nov 25, 2011. 11:02 AMmechanic bullet says:
what is the difference between CPVC and PVC pipe?
Nov 12, 2010. 8:50 AMsalazam says:
1/2 inch is too small for mine and 5/8 is too big. I've wrapped the ends of the 1/2 inch with a cloth tape, one time around, and it works but I have to find a good balance now maybe make the tips heavier because now they warble in flight.
Jan 8, 2011. 9:33 PMburning-ice says:
What is your barrel?
1/2" cpvc works great for 1/2"fbr....
Jan 8, 2011. 10:45 PMsalazam says:
Maverick stock barrel are the primary weapons of choice, then they also work in the clip loading ones, but aren't as powerful. What I have is caulk-saver from the Home Depot and maybe that's why the circumference is insufficient.
Aug 30, 2011. 1:08 AMTheTicklemehellmo says:
If your stefans spin during flight, you need to make it lighter, not heavier. #6 washers or metal .20 bbs are recommended.
Aug 30, 2011. 11:16 AMsalazam says:
I ended up using SP30 split shot. Seems to work, especially with the hot glue on the end. Still getting inferior distance than the regulars on the clip guns, but not the mavericks.
Aug 30, 2011. 5:48 PMTheTicklemehellmo says:
For me, burning a hole at the bottom of a stefan with a hot glue gun seems to work. Also, making the stefan shorter than its' store bought counterpart seems t work better too, a recommended length is 1 1/2 to 2 inches.
Jul 20, 2011. 7:39 AMjumpingcat says:
WAT MODDING GUNS IZ THE BEST PART say i if you agree
Nov 13, 2010. 10:33 AMHeckHawk says:
Nice gun dude ! awesome !
Oct 19, 2010. 1:37 PMsonofstone says:
are you sure about the 22 inch barrel? i just modded my supersoaker just by hotglueing on a nitefinder barrel, but the darts spin out of control, and the darts go anywhere except for the point i'm aiming at. i know thats because the barrel is too short, but isnt 10 inches long enough? thnx
Aug 25, 2010. 6:42 AMjamesalex55 says:
Do these darts hurt more than normal darts and where can you get backer rod in the UK?
Aug 18, 2010. 9:57 PMTheMadScientist says:
cant find any record of a company referenced as K&G selling hobbyist metal products. closest i could find is a hobby specific company called K&S
http://www.oakridgehobbies.com/index.php/hobby-products-tools-paints-wood-metal-plastic-hobby-supplies/metals-tubing-strip-stock-sheets-rods-brass-aluminum
could original poster confirm/deny weather this is the brand he was referring to?
Jun 23, 2010. 5:23 AMsneakpeak123 says:
epic fail your cut is bad
Jun 18, 2010. 2:04 PMInnocentassassin says:
ihave this old toy crossbow that i got for 10 bucks and i am tryin to make a bolt action airsoft gun out of it. get back to me if u can help. i has a groove down the middle that can fit the barrel from the extender of a longshot and i was going to try to use the same mechanism as the longshot but i dont no how to fit an airsift barrel on it......
Jun 14, 2007. 1:29 PMNerfModder1212 says:
does it matter how long the barrel is?
Jun 8, 2010. 9:05 PMVersatileHobbies says:
barrel length matters for modded water guns i recommend a 22inch barrel
Dec 19, 2007. 11:04 PMweponary101 says:
the longer the more accurate u get
Aug 31, 2007. 5:02 PMSHADOW HUNTER ALPHA says:
Yes. Extremely strong air-powered guns such as this will benefit most from barrels about 2 feet long. The barrel should also be a loose fit on your darts, but not loose enough that they can fall out on their own. Also, you may want to open the gun up and see if there is an "Over-Pressure Release Valve," what we in the Nerf Internet Community (NIC) abbreviate as "OPRV." An easy way to tell if a gun has one is to pump air and listen for a difference in tones in the later pumps. If there is a drastic difference, then there is an OPRV, which you can plug with hot glue or epoxy once you find it. They are usually located on the pump itself, and if not then somewhere nearby.
Nov 12, 2007. 1:13 PMnerfer192 says:
oh yeah? i have the internals of an at3k modded to be a 1pump yes i said one pump 60 foot super pistolthat gives welts and rips darts as thyer comin out the brrel that only sumtimes though but it makes my unweighted stefans wobble. SUCK!
Aug 5, 2008. 10:07 AMCapnTac says:
Awesome! Un-weighted stefans? WTF? They have to be waited if you want them to be of any use.
Aug 5, 2008. 6:32 PMnerfer192 says:
yes i know my mom is anti bb gun so i don have bbs
Aug 7, 2008. 8:17 AMCapnTac says:
Oh. You can use metal washers, too. They work pretty good.
Dec 27, 2009. 1:22 PMmilsorgen says:
 use small rocks
Jul 17, 2008. 4:28 PMEvilthingamabober says:
I have no idea what you just said
Dec 19, 2007. 11:07 PMweponary101 says:
do you have a site where i can get step by step instructions on how to make this gun?
Dec 20, 2007. 12:05 PMnerfer192 says:
<a rel="nofollow" href="http://www.nerfhaven.com">click here, itl help.</a><br/>
Nov 12, 2007. 1:20 PMnerfer192 says:
whoops that comment was to mykaihlo
Jun 18, 2009. 4:46 PMty.tdog says:
could you please possibly post a video of this gun shooting??
Apr 25, 2012. 11:43 AMVersatileHobbies says:
go on youttube and type SS Flash Flood Nerf gun and theres a vid of a guy shooting it it is'nt this guy but the gun was modded similarly
Nov 8, 2008. 11:18 AMdeadpyro says:
Would the kind of water gun that shoots water every pump work?Appreciated if you have an answer because i want to get into Nerf.
Jun 8, 2010. 9:02 PMVersatileHobbies says:
any water gun that is a supersoaker product dat requires pumping and then puling the trigger will work cut of the nozzle and glue on a barrel or coupler =)
Jun 22, 2009. 9:04 AMgeodez says:
super soakers?
Nov 14, 2008. 12:21 PMnerfman44 says:
Uh ya i guesse it could my friend has the one you are talking about and it is a little bit worse then the other ones that you pump and then shoot. but it will work over all i helped my friend with that and he loves it. oh and the dude below my comment it will shoot water.
Jun 14, 2009. 9:46 AMAJBrawlLvr says:
Does it work w/ a SS max-d 5000? thats the type I have. also-what diameter should the barrel be?
Jun 8, 2010. 9:00 PMVersatileHobbies says:
any gun from the supersoaker that requires u to pump it then pull the trigger will work cut of the nozzle that restricts air flow and glue a 1/2 inch diameter barrel or coupler for interchangeble barrels and longer barrels for water guns work the best i would recommend a 22inch long barrel =)
1-40 of 320next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:barnes
Computer Engineering Student at Drexel University, Intern at NextFab Studio.
