Nerf Jolt Airsoft Gun
Introduction: Nerf Jolt Airsoft Gun
Step 1: Gather These Tools and Materials
Nerf jolt, nerf dart, pipe or straw big enough to fit an aiirsoft bullet, or small bead, but small enough to fit in the dart, paperclip, scissors, drill and 2mm drill bit.
Step 2: Dart Decapitation
Cut the tip off the dart.
Step 3: Drill a Hole
If you have not removed your jolts AR, and the pin inside the barrel is still intact, this will not be necessary. If you have, drill a hole about a cm from one end of the pipe. If this step is not for you, skip to step 6
Step 4: Paperclips!
Cut the paper clip so it looks like this:
Step 5: Insertment
Insert the paper clip into the hole you have made so it looks like this. You will have to bend it to achieve this.
Step 6: A Spot of Plumbing
Insert the pipe onto the nerf dart, like so.
Step 7: Load It Up!
Put the airsoft bullet into the jolt, and insert a bb.
Step 8: Fire!
Step 9: Headless Dart
If you pull the excess foam off the dart head, it fires that as well!
Step 10: Blowdarts
If you remove the paperclip thingy, it fires my blowdarts quite well. See Best Blowdarts Ever! For how to make them.
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    sorry if this is a stupid question but is there a way to stop the bb from rolling out? thanks!
    You may reinterpret hmbmideas :)
    FYI Kiteman I make insructables so people can make epic junk
    That's why people post Instructables; for other people to copy.
