Nerf Jolt Mod
29,486
13
18
Posted
Introduction: Nerf Jolt Mod
This is a simple rubber band mod for the Nerf Jolt. All it takes are some rubber band skills.
I apologize for the messed up pictures. Those will be replaced soon, as I am editing all of my first Instructables to make them better. Edit posted April 28, 2014. Hold me to it!
Step 1: Materials
You will need
-Nerf Jolt (Elite or N-Strike)
-Rubber bands (#64 work best)
Step 2: Loop
Hook band on plunger, then twist it over, then hook it over.
Step 3: Hook
Hook band around top of gun.
Step 4: Check
Make sure the band is hooked over the black overhang.
Step 5: You're Done!!!
Range should be improved. Enjoy! You can do this for multiple bands, until it becomes too difficult to prime.
  • Science of Cooking
    Science of Cooking
  • Pocket-Sized Contest
  • Spotless Contest
    Spotless Contest
15 Comments
Remember you can do this for multiple rubber bands!!!
This actually does not work too well. The stronger the bands the worse the range. There is an air restrictor that works against air flow. It tends to close the stronger it gets. The restrictor keeps the piston from bottoming out in the cylinder if there's no load/dart. If you remove that first then you'll see better range. Also, you can pull the head off the darts and trim some of the rubber neck off. Re-glue and the dart weighs less and gets better range. I've also trrimmed darts shorter to make them flush fit with the front of the barrel. This also reduces weight. Where did you get an orange one? I've only seen the blue ones here in Vegas.
removing the air restrictor actually damages the nerf gun.
You can remove the air resticter from the Jolt but its challlenging :P I did it xD
You can also do this with the Nerf Triad Ex-3! I did this on that one, it works too! Cool mod!
can I use this as a reference in an ible?
No problem! Go ahead! Thanks for asking! :)
Its more fun with the new jolt and needle darts or something :D or can use q-tips (take dart cut off front stick straw in duct tape straw to dart put in gun duct tape that to gun and put q-tip in) Very painful :D
