loading
Step 4: Removing the air restrictor
(deep breath) Thanks for the picture, Captianslug.com. Remove the bolt and plunger chamber from the gun and pull them apart. Take an electric drill and clear through the bolt, removing everything so it's a tube. Unscrew the back of the plunger chamber and remove the plunger. See the black thing at the bottom? Turn the plunger chamber upside-down and tap the bottom so the other thing falls out. drill out everything in the thing (another air-restrictor) so it looks like a funnel-shaped thing. Put the black connector thing back in the plunger chamber and reconnect the bolt and the plunger chamber, greasing the intersection as much as possible. (breathe out)
If you want to boost the longshot's power, do that mod and then cut off the front of the barrel with a dremel like this. It boosts it's power like 45%!!! Plus, as an added bonus, it kinda looks like the patriot from Metal Gear Solid!!! The only downside, you must sacrafice the clip-loading part of the gun and load in throgh the barrel after you pull the bolt back. The clip is just for looks.
<p>just cut it closer to the front of the gun, just in front of the dart tooth</p>
how far did you get your modded longshot to go?
looks almost like a halo magnum
if you dont cut it that close then you can still use the clip
It does look like the patroit gun from MGS all we need now is some sort of infinite mechanism lol.
Did this without wasting money, by getting an OMW Alpha Trooper kit and using the original spring from the AT in my longshot. Also, with this setup you don't need to upgrade the catch spring.
You can actually just take off the black &quot;shoulder stock&quot; connector and take the spring out. It is alot easier
will the main spring form the long shot's crappy little pistol attachment work in place of the recon spring? i want to keep my recon working.
no, too small. DON'T DO THIS MOD! it's a waste of $20. I've modded mine with a spring I bought and it gets about about 100 feet with air restrictors intact (I screwed up a longshot by taking them out). Captain Slug is an awesome guy. he posts on nerf haven all the time
can you give me info on the spring?
Here's a suggestion, if you go to a good hardware store just look for a good spring that will work. I should cost $1-2 to get.
no you cant the pistol's spring is to short
Good instructable, although your own pics would have been nice. Also ranges and more descriptive words would be appreciated. However props, because you're one of the first to post a longshot mod on this site (I think). I'm pretty much doing this same mod now accept I'm using an NF spring (I have three laying around and I'm not about to go blow 20 bucks on a recon). I'll probably post a write up on instuctables which will include pics. Finally, I'm pretty sure the recon barrel extension will hurt range because the dart will bounce around.
why are you covering your nerf longshot with duct tape.
why is your longshot so color full?
It's photoshop'd...
So I take it the Recon Barrel fits on the end Long Shot gun with out a single mod? That's good to know for cosmetic reasons. I like the look of the barrel to that useless second gun of the Long Shot.
Seemed to me that the second barrel doesn't actually do anything. In fact, I thought it made the shot worse... I've not REALLY tested this though, am I wrong?
Yup, but What if you removed the insides of the recon barrel leaving an empty space for the dart to move thru unimpeded, and making the gun look cooler?<br><br>If you made it so the recon barrel could still attach, you'd get all the desired cosmetic effect without the accuracy or range tradeoffs.
yeah it slows it down <br />
No, you are correct. Everyone from the NIC agrees so.
iv known that from day one
thanks man i am TOTALY going to make this<br>
Oooooooooooooo nice man double the power!!!!! i tried to take the air restrictor out but nooooooo it was frigin glued together and i accidently destroyed one of the screws AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!!!!!!!! DOES ANYBODY KNOW HOW TO TAKE OUT THE AIR RESTRICTOR WHEN ITS GLUED!!!!!!!!!!!!!!!!!!!!!!!!!!!!
<p>Don't try to take out the whole unit.&nbsp; There is a large black plastic circle suspended by three prongs.&nbsp; For each of the prongs, grab it with needle-nose plyers and twist.&nbsp; It should break easily.&nbsp; After you break them all, turn it upside down and watch all the restrictors drop out :).&nbsp; It makes a HUGE&nbsp;difference.&nbsp; My longshot went from flacid and worthless&nbsp;to awesome with just this mod.</p>
&nbsp;will any of <a href="http://www.amazon.com/ASSORTMENT-SPRING-200-PC-C/dp/B00099Z0IO/ref=sr_1_15?ie=UTF8&amp;s=industrial&amp;qid=1263854534&amp;sr=8-15" rel="nofollow">these</a> springs work?
No. They pull rather than push.
ye thx ;]
cool! ima try that with my new longshot&nbsp;and my new cs-6&nbsp;thx man ur a life saver
If you have a recon and are willing to sacrifice it on the alter of awesome, I&nbsp;just doubled up my longshot spring with my recon spring after taking the air restrictors out and the longshot is now insane.&nbsp; Our nerf wars might require eye protection from now on.&nbsp; Hit my friend in the chest at 35' during our test run and he grunts &quot;oooff&quot;.&nbsp; Makes the recon affectively useless, though I'm working on writing up a mod on how to make it work again!&nbsp; Gunna be awesome.
try making it rubber band powered
nice ill consider that......<br /> &nbsp;<br /> lol alter of awesome
Try melting the glue with a hairdryer or something?
well its too late man i trashed my cs6 i first tried cutting it open but crap I didn't even cut in the right spot to retrive the AR, I tried gluing it back together with a hot glue gun but my gluing skills suk and messed it up so i threw out every thing accept for some of the internals because I plan on getting a longshot and modding that with the internals plus with your advice so ill keep in mind man! thx anyways!!!!!!!!! ps i have to say WHEEEEEEEEEEEEEEEEEEEEEEEEEEEEE!!!!!!!!!!!!!!!! i suck at gluing
Lol you should have seen me when I was using a hot glue gun for my bottle cups instructable----many many burns <br/>
ahhhhhhh I'm used to burns eh one time i tried making a mountain of glue on my finger nail (it killed) I should make an instructable on that eh?
You shoud lol
seriously where did everyone get that happy face photo
What my Picture? Its the Awesome Smiley Face.
&nbsp;lol :)
Snake? Snake?! SNAAAAAAAKE!<br />
BADGER BADGER BADGER BADGER BADGER BADGER BADGER MUSHROOM MUSHROOM <div style="background-color: rgb(255,255,255);padding-top: 5.0px;padding-right: 5.0px;padding-bottom: 5.0px;padding-left: 5.0px;margin-top: 0.0px;margin-right: 0.0px;margin-bottom: 0.0px;margin-left: 0.0px;font-family: Arial , Helvetica , sans-serif;font-size: 12.0px;display: inline;">&nbsp;</div>
a potter potter potter potter potter potter weasley weasley
snaaaaaakkkkkkkkkkkkkkkkke look its a snake!
SNAAAAAAAAAAAAAKE! *Points to a snake*<br />
SNNNNNNNNNNNNNAAAAAAAAAAAAAKKKKKKKKKKKKKEEEEEEEEEEEEEEEEEEEE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Haha I tried that too! I thought that there were no nerves in the finger nail, but as we know know I was sadly mistaken.
nice
Off topic, but, Ranges?
About This Instructable
105,853views
27favorites
License:
Bio: I like burning things and making things :]
More by Zippy_Pyromaniac:PET Bottle Stowaway Easy Funky Drinking Glasses from PET bottles Airsoft Target for High FPS
Add instructable to:
