Step 1: Disassembly
Take out the screws on the slide first. then pull it off. Then take all the screws out and pull your Maverick apart. You should see this.
1-40 of 108Next »
arshswag says: Jun 17, 2013. 6:34 PM
Great amazing mod
CanadianCraig says: Mar 17, 2013. 2:35 PM
I have the rod and the spring attached, And everything looks perfect but when I pull the trigger there is a loud bang but no bullet gets shot. Im somewhat confused
jjone538 says: Feb 8, 2013. 10:14 PM
Can u PLZ help me!!
I put my Maverick back together and the grey loading thing wont catch on and load properly. PLZ Tell me how to fix! @maxmaz2
ace12345m says: Sep 28, 2012. 11:46 AM
it's called the fall out mod not the barrel mod
firelord88 says: Jan 18, 2011. 2:57 PM
ok so this wrecked my gun some how, lol at first i thought maybe i had messed something up internally but i opened the thing up, as well as an unmodded one and they are both identical, i have no idea whats going on, but it sound like its skipping when i pull everything back, and i pull the trigger, it shoots forward but the gun doesn't fire the bullet i don know whats going on
ncc 1701 in reply to firelord88Oct 31, 2011. 5:11 AM
there is a catch that goes around the spring and clicks in to place with the pump so that when you pull the trigger it closes the pump, there is a small bit of plastic on the catch that sometimes gets ground smooth. i'm not sure how to fix it but that might be your problem. hope that helped
jaberwaukee in reply to firelord88May 31, 2011. 1:23 PM
replace the spring
pbmillar12 in reply to firelord88Feb 21, 2011. 11:49 AM
I had that same problem. If you dismantle the gun again, near the top you should find a long and skinny little spring that has a loop at one end. Put the half of the cocking handle with the pin on it through the long hole and hook the loop onto the pin. When you reassemble it, it should work.
GASSYPOOTS in reply to pbmillar12Apr 4, 2012. 5:29 PM
i have to put the other halve on to do it :(
Mr_Moosey says: Oct 26, 2011. 9:33 PM
I have extra pieces. there is a tiiiny spring, and a little plastic piece with a hole and four prongs on one side, and what looks like a clip on the other side. please help!
Ghostmaker says: Oct 16, 2011. 9:41 AM
What you're referring to as the "barrel" is the cylinder of the gun. The barrel is the orange piece the dart emerges from when fired.
xXSHORTYXx says: Jul 30, 2011. 8:28 PM
Did every thing but once I put it together I can pull back the top so I can't shoot ??? Help??
janderson50 in reply to xXSHORTYXxAug 4, 2011. 5:16 PM
The slider has a thin rod in it. If you look inside near the top, there's a spring with a loop in it. Make sure the rod goes through that loop. Might help you.
mfrench2 in reply to janderson50Aug 17, 2011. 9:17 AM
that is what i did wrong the first time and then the barrel didnt rotate
zuko123 says: Aug 4, 2011. 4:05 AM
THE BARREL IS THE LON THING
yodaboyben says: Jul 19, 2011. 4:41 PM
hey i did this mod before but not with this tutorial, but it works perfectly fine! :)
ivolpe says: Jun 21, 2011. 1:56 PM
hey i have a question about this, my maverick is broken because of me tring this mod and now when i reload it makes a loud poping sound and dosen't fire. how do i fix it?
korgoth25 in reply to ivolpeJul 10, 2011. 10:24 AM
your back barrel might nnot be alligned. thers a similar mod but its to the revolving casing only same steps except instead of shaving the actual gun (the blue pic in step 3) u shave the barrel there
EngineerJakit says: Jul 5, 2011. 10:44 PM
Who knew a small change to the frame would have such a neat effect?
Capt. Kidd says: Jun 20, 2011. 11:09 PM
it's called a cylinder. the barrel is the orange thing sticking out the front of your maverick. ya'know, the one the bullet travels through?
sub893 says: Jun 11, 2011. 12:05 PM
I tried it out and it works well but I used a coping saw instead of a file.
pyro man says: Dec 9, 2008. 7:23 PM
all it does is go out farther?!!?!!? wow
sole in reply to pyro manJun 4, 2011. 5:02 AM
Not just that, it also allows the barrel to spin freely for a safe game of russian roulette.
maxmaz2 (author) in reply to pyro manApr 6, 2009. 11:17 AM
hey its nothing big but its pretty cool
mg0930mg in reply to pyro manFeb 16, 2009. 6:15 PM
I think it is better.
maxmaz2 (author) in reply to pyro manDec 12, 2008. 4:24 PM
after the fact i took the barrel out fully
hdn_5 says: Mar 4, 2010. 7:57 PM
How did you take out the I dont know stick things inside each chamber of the barrel? Does it improve preformance?
indestructibleguy in reply to hdn_5Aug 19, 2010. 3:34 PM
it improves performance, but not much more than 10 feet. works great though! check this out, it's a removable turret: http://nerfhaven.com/forums/index.php?showtopic=83670
pbmillar12 in reply to indestructibleguyFeb 21, 2011. 11:51 AM
I know it improves performance, but how do you do it?
smash10101 in reply to pbmillar12May 4, 2011. 7:18 PM
open up the gun like in the guide, then open up the cylinder thinggy, you have to pull out the metal rod which can be kind of hard. Then cut the sticks with a wire cutter or clippers or scissors or w/e and remove the plastic things on the tiny springs
tranoxx says: Mar 12, 2011. 2:59 PM
does the gun still work regularily?
maxmaz2 (author) in reply to tranoxxMay 4, 2011. 2:52 PM
Yep, 100%
P.I. Kitty says: Jan 12, 2010. 6:46 PM
kinda hard 4 me
P.I. Kitty in reply to P.I. KittyJan 12, 2010. 6:39 PM
(removed by author or community request)
pbmillar12 in reply to P.I. KittyFeb 21, 2011. 11:52 AM
I used a steak knife to do mine... it worked to amazing effects
heavydeath says: Feb 7, 2010. 9:58 AM
 wats the size of the tip of the barrel as i want to make a silencer anser quick
pbmillar12 in reply to heavydeathFeb 21, 2011. 11:52 AM
idk
cleage001 says: Nov 6, 2010. 11:00 AM
some call this the russian roulette mod
Air_Assassin in reply to cleage001Jan 5, 2011. 3:43 PM
ok?
revtiedye says: Dec 23, 2009. 5:21 PM
I'm sorry to be so anal about this, but I was quite confused until I realized you what you were calling a barrel, is what I've always called the magazine.  I'm pretty sure the barrel is the long tube where the compression builds up behind the bullet.
1-40 of 108Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
