3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Nerf Maverick Video Modification Guide
A series of videos showing how to modify your Nerf Maverick blaster in various ways including assembly, disassembly, laser sight, penny mod, russian roulette mod, slip clutch / reliability mod and air restrictor removal. The Maverick happens to be a cheap and easily modifiable Nerf gun that's perfect for inexperienced modders. Hopefully these videos can assist you in your Maverick modification adventures.
Please consider subscribing to my YouTube channel or liking my videos.
Step 1Disassembly
Disassembly
Runs you through the processing of pulling the Maverick apart in preparation for some modding. Just make sure you keep an eye on all the parts as some are easy to lose.
28 comments
Apr 4, 2012. 4:41 PMGASSYPOOTS says:
uhh my pull back thick is made in reverse of yours so how do i put it back on???
Feb 20, 2012. 5:00 PMFarrelbark says:
okay, just found out the pin caps on the cylinders were put in backwards....
Problem solved.
Feb 20, 2012. 4:30 PMFarrelbark says:
I just did the Air Restrictor Mod, the Penny Mod, and the Russian Roulette Mod.
The first two work wonders, and the last one comes out correctly, but it's very wobbly when it's popped out and it sticks on something when popping back.
Jan 14, 2012. 12:09 PMthe poodleo says:
AWESOME!!! these mods worked great. I used the one to make the barrel go out further, the penny mod, and i removed the air restritors. i also painted it- gold, and im doing some brush work with black and silver right now. this was a great instructable, i would love to see mods for the nerf barricade. ill post pics when i finish my gun too.
Dec 21, 2011. 5:44 PMdragondane says:
Hey again,
I've done heaps of Nerf Modding now but i'm kinda stumped on something.
My Maverick is a model from 2009, (Don't know if that has anything to do with it) but anyway when I try to quickly load it, say pull the slide back and let go, it just kinda jams, skips a barrel on the turret. So when in a war I don't want to spend time slowly cocking the gun while being shot at. I've checked the catch spring, the slide spring and the plunger spring and it's still not loading well.
Thanks for your answers.
Nov 12, 2011. 1:16 AMdragondane says:
My Maverick is now broken, any suggestions on why it might be broken? When pulling back the slide it automatically fires, with no bullets being shot? I don't even need to pull the trigger. Please suggest some helpful tips how to fix it. And the spring underneath the plunger, connecting to the little sticking out piece may be the problem. I only tried the penny mod and the AR removal.
Thanks in advance.
Nov 12, 2011. 3:47 PMdragondane says:
Thanks a heap!! All good. Proves 12 year olds, (with some help), can mod a nerf gun. Turns out the spring underneath the orangey thing was connected to the ridge, not just pushing against it, (Hard to understand, sorry)
But thank you!!!
Nov 2, 2011. 1:30 PMncc 1701 says:
would taking out the centre of the piece that fits on top of the air restrictor make the gun even more efficient?
Nov 3, 2011. 10:11 AMsa10a10xjr says:
thanks man that was really helpful
Sep 20, 2011. 4:20 PMtyler303047 says:
What does removing the air restrictor do?
Sep 27, 2011. 4:00 PMInventor X says:
Think of the word "restrictor". It sounds a lot like "restriction", doesn't it?
So the purpose of one's "Air restrictor" is to control the amount of air that pushes the bullet out of the chamber. By removing such a device, it unblocks the small amount of air that is usable to fire the bullet forward. This makes the bullet travel, consequently, a lot further than normal.
Sep 20, 2011. 4:21 PMtyler303047 says:
Sorry didn't clear that up, but will it shoot a lot farther and faster without destroying the darts?
Sep 5, 2011. 8:28 AMLil C says:
sweet how far was yours able to shoot after the mod
Sep 7, 2011. 4:31 PMLil C says:
ok cool
Aug 20, 2011. 11:02 AMCaseBoy says:
check out my maverick
Aug 22, 2011. 12:31 AMshadow wave rider says:
what is that thing at the front
Aug 29, 2011. 3:07 PMCaseBoy says:
a round drum from a nerf firefight
Sep 5, 2011. 12:53 PMzcbaker says:
Not to be rude, I'm OCD so it bugs me that you called the firefly a firefight.
Sep 7, 2011. 11:56 AMCaseBoy says:
i am always forgetting the name of the gun, so its cool
Aug 31, 2011. 6:02 AMspiffy956 says:
Two things:
1: Should we use any glue or epoxy for the penny mod?
2: I tried the air restrictor removal and penny mods and the distance the gun shoots is the same as before. Do you have any other suggestions for getting more distance?
Aug 19, 2011. 12:48 PMross33 says:
im about to do this lol very nice
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:x2Jiggy(x2Jiggy.com)
A tech and gadget enthusiast who enjoys building and creating DIY projects. Check out my projects and tutorials on Instructables and x2Jiggy.com!
