3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Nerf Maverick no-damage full barrel removal mod
makes the barrel come out all the way so if you have two you can switch 'em out no damage totally reversible (if you don't break anything)
P.S. the reason my slide is not on is because its broken
Step 1Unscrew
unscrew
take all the screws out of the slide first then pull it apart then take the screws out of everything else then pull it apart when you pull everything apart push the yellow button on the other side and take the barrel out
17 comments
Mar 18, 2011. 10:57 AMnbagf says:
this is very confusing! can someone tell me this step in simpler words please? Too much "orange" and "black" not enough description.
Sep 4, 2009. 7:55 PMJasonMyers says:
Ok. I have a newer Maverick, and it's the yellow one. It has some black and orange guts, and the barrel has no spring. How do I get the two parts off without breaking it?
Jan 1, 2011. 6:50 AMhmm... says:
So. You take a hammer and one of those things that you use for small headed nails and hold the thing between your legs and whack it. :)
Mar 22, 2010. 4:25 PMMAVREV13 says:
nice mod but what all mods did you do besides the obveis also check my modded Maverick out also do you think the maverick is a good gun 1-10?????
Nov 25, 2010. 6:03 AMbasher345 says:
i would have to say... 6/10
Jan 21, 2010. 2:08 AMmaveric__fil says:
wuoldnt it be cool if you cuold remove them and put a reloaded one back in
Jan 21, 2010. 4:28 PMmatstermind says:
you can
Mar 25, 2009. 2:17 PMTemp. says:
I am really bad at moddin nerf guns so I was wondering if you could explain how to take out the rod so that I can remove the big grey pieces. Thx
Aug 5, 2009. 1:10 PMNerfgenius says:
Or even put a phillips head screw driver under the top little thing and pry upward
Jul 9, 2009. 1:49 PMShredder543 says:
W00T First rate =)
Jul 9, 2009. 1:51 PMShredder543 says:
?? I rate five and it gives you 3.09... ???!!!!
Jul 9, 2009. 5:08 PMbobby4505 says:
lol
Apr 28, 2009. 5:01 PMgdogtx says:
yeah that worked for me, though it was a pocket knife. be really careful, you can cut yourself very easily. if you can get enough leverage, the rod should come out of one of the pieces and you can pull it through
Feb 2, 2009. 6:59 PMportalguard says:
Hey there, I tried doing a mod like this recently. I took all the airflow regs out and i couldn't get my maverick to fire a dart very far. So can i ask how well does your fire darts?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:maxmaz2
