This Instructable will introduce you to the vast world of Nerf gun modifications. It covers basic concepts of Nerf gun modifications written for complete beginners--those who are interested in Nerf guns but unsure of how or where to start.
Remove these ads by
Signing UpStep 1Why Nerf?
But, in the end, it is really all a matter of preference. If you really want to read a more in-depth article about this, here's an article from NerfHaven.com - Nerf Vs. Paintball
Tippmann A-5 image courtesy of sebaraya.com
Nerf Nitefinder EX-3 image courtesy of hasbro.com
Airsoft Rules
The Red Afternoon
Trust me I'm a doctor
But, it seems like what you have is working. However, I can't imagine that the tape will hold for very long. You may want to try a glue, like epoxy.
Another, easier option would be to create a simpler breech system that would "single" the Longshot. In other words, if you make this type of breech, you won't be able to use clips and you'll have to put a dart in manually between shots. There are a couple of these, like this mod.
You could also just leave it like it is, with the stock breech setup. Whatever you decide to do, good luck!
But, if you have something that calls for a longer barrel, chances are that it won't shoot stock darts very well at all. The barrel is long so that the stefan will fly a far distance and have a stable flight. If you front-load a stock dart, the gun will probably fire it and cause the stock dart to spin out of control. Longer barrels are generally used for more powerful guns, and if the dart doesn't have a long barrel to travel down (stock darts don't because they're loaded in the front of the barrel), the dart will spin out of control. So, if you are modding a Nitefinder or similar weaker gun, stock darts will probably work just fine.
Epoxy+Goop+CA Glue(Super glue)
Then, take the air restrictor and glue it to the dart, i used Tacky Glue, but im sure others would work, just not hot glue cuz it melts the darts.
My stefans are CaptainSlug's stefnas. This method of stefan making is the less-popular method of making darts, but I find that I produce better stefans following CaptainSlug's method.
There are also a number of instructables on making stefans. Just search "stefans."
Enter the item's part number into the McMaster "find" bar. They are as follows:
Felt Discs - 8771K22
Washers - 91083A009
Foam Backer Rod (If you can't find any at hardware stores) - 93295K43
Mind you, that foam backer rod comes in lengths of 250 feet. That's why it's so expensive ($35).
