Step 11Spring Guns - Spring Replacement
Replacing the spring on a gun is very simple. You first must choose your spring. If it is necessary, you must cut down your spring to a length very close to that of the stock spring. A spring should be cut either with bolt cutters, or a Dremel with a cut-off wheel attachment. Other tools might break if used to cut a spring. Once your spring is cut, it is ready to be put in your gun. You can remove the plunger head (usually by unscrewing it) then take out the old spring. You can then put the new spring in its place. Other approaches to spring replacements include adding an extra spring and even stretching the stock spring. However, stretching your spring can cause it to break later, so it is not recommended by experienced Nerfers.
Epoxy+Goop+CA Glue(Super glue)
just saying this incase anyone else thinks of trying it, if you can get it to work please tell me
As for the plunger head, I haven't actually seen a mod that directs how to reinforce it. However, I actually have had a plunger head come out of the rod when I was using a gun with a stronger spring! I imagine that you could smear epoxy where the plunger head contacts the plunger rod, then screw the head onto the rod. However, this would mean that you would not be able to take the plunger head off, if you needed to for whatever reason.
Of course, there's always the NerfHaven Modifications Directory! I can't guarantee you will find your answer by looking a Recon mods, but it may just help.
