3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Nerf Mods: A Beginner's Guide
Step 12Spring Guns - Seal Improvment
Spring guns use an O-ring to create a seal against the plunger tube. This seal, hoever, is not perfectly airtight. Although it does not seem like much, improving the seal by the slightest bit can really make a difference in range. There are three common methods to this:
Method 1: Simply replace the stock O-ring with another O-ring that has a better seal. O-rings can be purchased at a hardware store. Make sure that your new O-ring is not too large, because you want to have a good seal while keeping the ability to have the plunger slide around comfortably in the plunger tube. (Picture 1)
Method 2: Add a second O-ring to the plunger head. This method creates a great seal because there are two seals in the plunger tube. (Picture 2)
Method 3: Add a thin layer of electrical tape where the O-ring originally was. Then, put the O-ring over that layer of electrical tape. This stretches out the O-ring to a slightly larger size. In this plunger (Nitefinder) you do not even have to tape all the way around the plunger head. The layer of tape must be thin enough to allow the plunger to slide through the plunger tube comfortably. (Picture 3)
4 comments
Jul 28, 2011. 1:04 PMSaltyNerfer says:
Hey, i want to mod my long shot. I already removed the ars, and im going to replace the spring and o ring. Should i do the barrel, too?
Jul 30, 2011. 11:36 AMSaltyNerfer says:
Thanks for the help.
Jul 28, 2010. 9:06 PMpuppetmaker77 says:
What kinds of O-rings do you usually use for these different methods for a Nite Finder? Like what size? The ones on HomeDepot.com seem to be categorized by some sort of number system.
Jul 13, 2011. 12:14 PMArvex says:
Probably varies by which Nerf blaster's plunger you have.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:geek27
I'm Alec. I like to post Instructables whenever I get to work on my own projects. But, that isn't exactly all the time. I usually find myself pretty busy with school, so it's not often that I actua...
more »
