3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Nerf Mods: A Beginner's Guide
Step 13Pump Guns - Over-Pressure Release Valve Plug
All pump guns have Over-Pressure Release Valves. As mentioned in Step 6, this valve leaks air when the pressure in the gun is too high. So, for instance, if you pump a gun up to 35 PSI, further pumping will not result in any more pressure going into the gun. This is because the air you are trying to pump into the pressure chamber is just leaking out of the pump tube. This valve can be plugged to achieve higher pressures in the pressure chamber. This higher pressure results in a much higher range in Nerf guns. However, if they perform this mod, you must be careful. Pumping your gun way beyond pumping limit can result in your pressure chamber rupturing. Then, your Nerf gun will not function and will be nearly impossible to repair.
The actual modification is extremely simple. First, find the hole in the head of gun's pump. This hole is where the valve is situated. Using a hot glue gun, place a bead of glue over the hole, and once it dries, you're done! Just remember, be careful with plugged OP valves, you do not want to break your gun.
6 comments
Mar 30, 2011. 4:47 PMflashanimator says:
I tried to find the over pressure valve on the Nerf Airtech 2000 but could not find it. It appears that after you pump it the overpressure valve is a small two small plastic circles screwed together. I unscrewed these before and thats where the air must be held. If I were to hot glue the screws in place and seal all the places where air can leak out of it would that allow it to hold in more air?
Mar 30, 2011. 11:42 PMflashanimator says:
ok thank you, I thought it was that 6 screws totals two plastic circle thing, couldn't find it before guess i needed to unscrew the black handle. Thank you for the help.
Jan 24, 2010. 3:26 PMnathe0 says:
One solution could be to wrap a layer of duct tape (or similar) around the existing pressure chamber. This would at least provide some additional support.
Jan 27, 2010. 3:22 AMnathe0 says:
I admit, it would be tricky. Even another 5-10psi (or just added safety at regular pressure) would be good though.
My flat-mate (a pilot) recommends the patch tape they use on aircraft, its a tougher, stickier version of duct tape than you get at the hardware store.
Often called "100 mile an hour tape" as its used to make temporary repairs to the outside of aircraft.
Sep 14, 2009. 2:38 PMMichel7788 says:
couldnt you reinforce the pressure chamber or replace it with something metal? i doubt anyone would have the muscle power to rupture a metal one, and i'd think the glue (or the entire valve?) will rupture first by then
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:geek27
I'm Alec. I like to post Instructables whenever I get to work on my own projects. But, that isn't exactly all the time. I usually find myself pretty busy with school, so it's not often that I actua...
more »
