3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Nerf Mods: A Beginner's Guide
Step 3Common Modifications List
Here is a list of the most common mods done to Nerf guns. Modifications vary depending on what type of gun you are modifying. There are two main types of Nerf guns: Spring Guns and Pump Guns. There is a simple way to classify whether a gun is a Spring Gun or a Pump Gun: how you prime the gun. A Spring Gun is primed by a cocking mechanism. A Pump Gun is primed by being pumped a certain number of times.
--- Spring Guns ---
  • Air Restrictor / Air Limiter Removal
  • Spring Replacement
  • Seal Improvement
  • Barrel Replacement
--- Pump Guns ---
  • Over-Pressure Release Valve Plug
25 comments
Mar 9, 2011. 9:48 PMafireball says:
What mods for deploy cs-6
Apr 10, 2011. 9:19 PMjongscx says:
Almost all of the nerf CS blasters use the reverse plunger system. As such, any mods for the Recon, Raider, Alpha Trooper, etc are almost all applicable to the Deploy.
One big thing about the deploy is to be very careful when disassembling. The Large spring that pops out the stock, is always tensioned, so it can literally blow apart just by taking the screws out.
AR removal is the simplest, followed by plugging air leaks, and buffing up the O-Ring. Another possible one is Spring replacement, but you'd need to find just the right kind of spring.
Jul 2, 2010. 2:37 PMmatt17fan says:
what about the new 35 shot ones? Where do they fall in?
Feb 4, 2011. 7:30 PMmaximus276 says:
dear matt17fan regarding your Question of "the new 35 shot ones" they are spring compressed and to modify it you would treat as the Nerf Recon even though they are raiders themselves and I suggest that you cut off the end of the barel and attach the extended barel on to it.
Dec 31, 2010. 2:03 PMFamoosh says:
The Raider falls under a spring gun.
Sep 9, 2010. 1:04 AMsmithy123 says:
a nite finder can fit 2 o-rings cant it and how long is the cpvc 1/2" is is 3" or 4"  tell me plz and wat springs can i put is a nite finder as well thanx
Nov 17, 2010. 9:06 PMBlacksunshine420 says:
You can find the springs at ACE hardware a #49 is the one you want. One that is somewhat popular is from home depot. Its made by everlong and is a 24lb spring. you will need to cut it down about 1/2" -1" or it will be very difficult to prime your gun. It will eventually destroy the gun tho. Another popular spring comes from MCmaster-carr. I forget the spring size off hand but you can find this info on Nerfhaven.com. Also some people will use part of an AR15's buffer spring. Cut a 4" section off and toss it in. You will also need a stronger spring for your catch plate or it will not be able to hold the tension from the heavy spring.
Here's one of my creations.
Dec 22, 2010. 1:17 AMRevan_Taros says:
ACE #49. buy it at Ace hardware stores
Jul 10, 2010. 7:09 PMubcrazy2 says:
how big is the cpvc
Jul 12, 2010. 3:24 PMubcrazy2 says:
i mean how long is it for my reference
Oct 14, 2010. 4:08 PMBluePhenox says:
thats what she said...
i just had to.
Jul 13, 2010. 12:54 PMubcrazy2 says:
k thanks
Feb 14, 2010. 9:48 AM~Z~ says:
 Where can i get the o rings? i just threw one away....
Jul 6, 2009. 2:13 PMseabee890 says:
OMG!!!! I have seen about 15 of the belt fed nerf guns at my local goodwill in this year alone.WHY DIDN"T I FIND THIS SITE SOONER!!!! WAAAAAA LOL! Excellent info thanks.
Oct 23, 2009. 7:18 PMseabee890 says:
i just pick up the sniper rifle and the recon cs-6 so i can modify them but i need to know how
Jul 13, 2009. 11:10 AMScubaSteve says:
there is one vulcan mod that ive heard of. Basically, what you do is remove some resistors and amp up the elecrtic current to make it fire between 200 and 300 RPM!
Dec 16, 2009. 8:08 AMGeekBeam says:
why not slow the firing rate down while extending the range it wouldn't use as much darts while being accurate it would work as a turret gun in a nerf war which would be nice
Oct 22, 2009. 4:41 PMH3xx says:
Yes but it does have a single fire mode that is fairly accurate. my lil bro has one and i get him to drive a remote control car around while I use it for target practice.
Aug 20, 2009. 5:06 PMlaxdude says:
haha my friends nitefinder shoots pretty well even w/o mods
Aug 12, 2009. 4:01 PMassasin32 says:
i really get dissapointed when all these nerf guns have the worst range ever i mean they r brand new out of the box and they just plop out of the barrel the thing is that i want to pimp out my nerf guns but i am not exactly a genuis about mods
Jul 31, 2009. 3:57 PMcitason says:
y didnt u just put in both springs
Aug 2, 2009. 10:31 PMThundertydus says:
Because itll probably break the priming handle on the gun If putting 3 pennies into a nerf maverick can break it, Figures a second spring will do the job as well
Jul 3, 2009. 4:13 PMOmarZRG says:
Wow, Hasbro actually puts limiters in their guns? No wonder their range is so disappointing...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:geek27
I'm Alec. I like to post Instructables whenever I get to work on my own projects. But, that isn't exactly all the time. I usually find myself pretty busy with school, so it's not often that I actua...
more »
