3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Nerf Mods: A Beginner's Guide
Step 5Understanding Spring Guns (Part 2)
Picture 1 is an exploded view of the barrel. The parts next to the actual barrel itself connect the barrel to the plunger tube, but also limit the air flow in the gun. Later, we will discuss these parts that limit a gun's range.
Shown in Picture 2 is the catch mechanism. It is a part that is normally over the plunger, but is shown by itself so you can see it. Picture 3 shows the plunger without the spring or catch mechanism on it. see that curved part on it? That is where the catch engages, or put in simpler terms, where the gun cocks. The curved part of the plunger, when pulled back to the catch, forces the catch up. At the end of the curved part, the spring on the catch forces the catch down. Notice that the plunger cannot move forward, because the catch keeps the plunger from moving forward. Pictures 4 and 5 demonstrate the gun in its cocked position. Note that the curved part of the plunger is stuck behind the catch.
When the trigger is pulled, the catch is forced up and the plunger shoots forward, compressing the air that pushes the dart out of the barrel. You can see how the trigger forces the catch up in Picture 6.
If you do not understand this or it is unclear, this is fine. I suggest you buy a Nitefinder for modification, as mechanisms will become clear when you disassemble the gun. Even if you don't quite know how a gun works, it is fine to open the gun, as long as you take caution not to lose any pieces. Opening the gun and tinkering with it yourself will help with your understanding of the gun's mechanisms. It is important to be careful but not to be extremely careful.
6 comments
Jan 18, 2011. 4:14 AMmsheppard says:
As noted in a lot of other Nerf mods: These pieces are glued together by the factory in newer guns. Getting them apart requires a hacksaw or a bit of luck cracking the plastic in just the right place.
Personally: I cracked it in the wrong place but after the rest of the mod was able to use Plumbers Goop to glue it back together and ended up with a far more powerful gun.
May 2, 2010. 1:47 PMben360 says:
 Ha! "It is important to be careful but not to be extremely careful." Yeah, that pretty much nails it.
Jan 30, 2010. 3:12 PMheavydeath says:
 ok im pretty stupid i tried to melt the glue on the outside of my barrel in my nitefinder ex3 i melted the whole barrel so everything in pic 1 wat do i need to do to make a new barrel and all
Jan 31, 2010. 12:56 AMheavydeath says:
 good mod but i melted the orange part u dremeled any other suggestions
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:geek27
I'm Alec. I like to post Instructables whenever I get to work on my own projects. But, that isn't exactly all the time. I usually find myself pretty busy with school, so it's not often that I actua...
more »
