Step 6Understanding Pump Guns
In the next picture, the gun's pump can be seen. Like the plunger of a spring gun, it has an O-ring on the front of it. This makes an airtight seal with the pump tube, shown in Picture 2. When pushed forward, the pump compresses the air in the pump tube, and a valve in the pressure chamber lets compressed air into the pressure chamber itself. This pressurizes it. When enough pressure has built up in the pressure chamber, further pumping will only release the air trying to be pumped into the pressure chamber. The object that is responsible for this air-release is called the "over-pressure release valve" and is shown in Picture 3. Additionally, you can see a close up of the pump tube and the pump inside of it in Pictures 4 and 5.
See the metal rod that the trigger is attached to in the next picture? This rod, when pulled back, releases the air in the pressure chamber. The trigger is attached to this rod, so pulling the trigger back will pull the rod back (see next picture), releasing the air in the pressure chamber . The air from the pressure chamber then travels down the barrel and fires the loaded ammo.
Again, if this is unclear, do not be too careful and try to understand everything, opening the gun will help your understanding, and it is unlikely anything will go wrong from simply viewing a gun's internals.
Trust me I'm a doctor
Maybe it's vaporized moisture, but that's just a guess...
