3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Nerf Mods: A Beginner's Guide
Step 7Barrel Replacements Part 1: The Stefan
This is an introduction to barrel replacements.
YOU MUST FIRST UNDERSTAND THIS CONCEPT: Nerfers make and use homemade darts called stefans. These stefan darts are very cheap, easy to make, and have great performance that achieve much higher ranges than stock Nerf darts. Shown in Picture 1 is a stefan in comparison to a stock Nerf micro dart. Notice how stefans do not have a ring of rubber on the end of the dart. This allows them to be loaded in the back of long barrels. Nerf darts have a ring of rubbery material on the front. This is sometimes referred to as the "neck" of the dart. In barrels in which stefans load in the back, Nerf darts load in the front, as the neck of the dart prevents it from being pushed in farther down the barrel. The concept of stefans being loaded into the back of the barrel, often referred to as back-loading, allows the dart to achieve ranges much higher than that of normal Nerf darts. Since the dart travels down the entire barrel, it receives optimum pressure when it leaves the barrel. Also, when stock Nerf darts are front-loaded in high-powered guns, they usually end up spinning out of control.
18 comments
Jul 21, 2011. 4:57 PMmjames-books says:
do you have to use the stefans or can you just use normal stock darts will the fit in some mods????
Jan 25, 2011. 8:24 AMTSC says:
Were do you get Stefans?? Cause I can't find them!
Jan 25, 2011. 5:08 PMTSC says:
I know that there homemade darts! I mean were do you get the stuff to make the darts??
Jun 6, 2011. 3:58 PMwilliam_da_sexy says:
u make stefans yourself, lots of tutorials on i. GL
Jan 26, 2011. 5:32 AMTSC says:
OK thanks!
Nov 11, 2009. 4:39 PM5chidori says:
It's rear-loading not back-loading.
Apr 30, 2010. 3:37 PMD1rty Di3sel says:
In real guns, the proper term is "breech-loading"
Nov 10, 2010. 11:09 PMRevan_Taros says:
you mean like the m203?
Dec 2, 2010. 1:24 AMRevan_Taros says:
they are actually
Jul 13, 2010. 6:06 PMPizzapie500 says:
Lol I laughed when you wrote "Dear Mr. Crapper"
Oct 22, 2010. 10:20 PMPMSandaGun says:
lmao, so did I...I think I woke up my son.
Dec 30, 2010. 8:09 PMallenmt says:
LOL
Apr 7, 2010. 11:35 AMSaturn V says:
Who cares about which you use as long as people know what you're talking about?
Sep 12, 2009. 7:16 PMweasel999 says:
u can make darts from baker rod i
Jul 21, 2009. 5:11 PMxj561 says:
The nerf stream line darts have rubber heads but are flush with the rest of the dart.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:geek27
I'm Alec. I like to post Instructables whenever I get to work on my own projects. But, that isn't exactly all the time. I usually find myself pretty busy with school, so it's not often that I actua...
more »
