Step 8Barrel Replacements Part 2: The Barrel
1/2" CPVC
- Works with: micro stefans (back-loading) and Nerf micro darts (front-loading)
- Good quality material
- Very cheap material (a couple of dollars for 10 feet of 1/2" CPVC)
- Can be cut with a hacksaw, PVC cutters, pipe cutters, rotary tools, etc.
- Works in 1/2" CPVC couplers
- Very good quality material, gets great performance
- Material is quite expensive (up to 5 dollars for a foot of this)
- Can be cut with a rotary tool using a cut-off wheel. Other tools may be able to cut this, but most use a rotary tool
- Does not work in couplers
- Comes in many sizes, but sizes 9/16" and 17/32" are the two main sizes that Nerfers use for barrels
- 17/32" is the more common barrel size and has a tight fit on darts
- 9/16" has a looser fit on darts, but it works better for some people
- Very good quality material, similar performance to brass barrels
- Much cheaper than brass, sold by a vendor on this Nerf website for $0.50 a foot
- Can be easily cut with a hacksaw, pipe cutters, a rotary tool, or even scissors!
- Works with: Nerf micro darts (back-loading)
- Very cheap material (a couple of dollars for 10 feet of 1/2" PVC)
- Works in 1/2" PVC couplers
1.) One may nest their brass/PETG barrel in 1/2" PVC to protect the barrel, as brass tubes are prone to denting and PETG is prone to bending.
2.) One may nest their brass/PETG barrel in 1/2" PVC so their brass/PETG barrel can be used in a coupler set-up.
Note on nesting: 1/2" CPVC will not nest in 1/2" PVC, as the walls of 1/2" CPVC are too thick. In most cases, it is unnecessary to nest 1/2" CPVC in 1/2" PVC, because 1/2" CPVC is not prone to deforming as brass and PETG are, and 1/2" CPVC works in couplers as is.
I would recommend trying a different brand of CPVC or different foam to make your stefans. If you are sure that the seal isn't contributing to the low-ish performance of your blaster, then the only thing you can do really is just to try different barrelling or foam!
Would you care to elaborate on your idea? I'm not sure I understand what you mean!
Normal stefans are made with 1/2" foam backer rod.
Mega stefans are made with 5/8" foam backer rod.
In addition, mega stefans often use heavier weights.
