Nerf Modulus Stock Reinforcement
2,178
Published
Introduction: Nerf Modulus Stock Reinforcement
When you first get the Nerf Modulus stock you'll find it very flimsy. The orange plastic struts simply aren't stiff enough to give the stock a decent feel. This instructable will show how to easily reinforce those to make a good sturdy stock.
This requires only a few simple things.
A few inches of 1/2" CPVC
A cutting wheel or saw.
Sandpaper
Superglue ( optional )
Paint &/or Vinyl Dye ( optional )
Step 1: Opening the Stock
First remove the 5 screws that hold the stock together & set them aside. You'll see that the orange struts form a U shape inside the back end of the stock. Cut out the center portion of the U Leaving two straight struts as shown.
Step 2: Trimming the Struts
The front end of the stock will now resemble this. Round off the pegs on the end of each strut as I have on the lower one.
Step 3: Test Trimming Size
Grind off the pegs until the Cpvc will slip over them.
Step 4: Fine Tune the Trimming
Cut two pieces of the Cpvc to the length of the exposed part of the struts. Remember always cut long. It's far easier to sand away extra than to come up short & have to start over. Sand the ends of the CPVC smooth and test fit repeatedly until your new strut reinforcements fit snugly in place.
Step 5: Test Fit - Glue ( Optional )
Done properly they will fit quite tightly. For extra strength you may even consider super-gluing the front ends of each to the locking mechanism block. ( optional )
Step 6: Reassemble
Replace the second side and replace the screws. Your improved stock will be far stiffer than the original and still snap on & off almost any gun cleanly.
Step 7: Paint ( Optional )
Now just paint to match your blaster ( optional ).
I recommend using the Paint & Vinyl dye spray you find at most auto parts stores. Unlike typical paints it soaks into the plastic to color it making it far more flake & scratch resistant. If you want to tape off some of the edges between colors use electrical tape as the dye can soak through normal painters or masking tape.
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    5 Comments
    Thanks. I'm now trying to work out how to do something similar to my Recon stocks. They have an even worse case of the same issue which is why they're usually cheap. Unfortunately the shape of the struts is a little more complex and I'm looking at having to punch out the connector pins on the lock mechanism side in order to add the reinforcement.
    I know. I have tried everything but nothing works
    I've gotten one completed & the instructable is up.
    https://www.instructables.com/id/Nerf-Recon-Retaliator-Stock-Upgrade/
