Nerf N-strike Jolt Mod
7,090
8
Published
Introduction: Nerf N-strike Jolt Mod
In this instructible, I will show you how to mod the nerf jolt.
Step 1: Getting the Tools
You will need: a power drill, a small screwdriver, a big screwdriver, pliers, and extended pliers.
Step 2: Taking the Blaster Apart
I used the small screwdriver to take the gun apart. If you're having trouble taking the gun apart, use a bigger screwdriver. Also, make sure you put the screws in a safe place.
Step 3: Removing the Internals
When you unscrew the bottom of the blaster a mechanism will pop out revealing the Ar, put it aside.
Step 4: Removing the Barrel Post
Use your long nose pliers to take out a plastic rod in the barrel of the blaster.
Step 5: AR Removal
Take out a spring and a plastic piece located in the top of the blaster. Then use a drill to take out the rest of AR.
Step 6: Assemly
Assembling the gun is easy. Just put back the screws and you're done!
    • Oil Contest
      Oil Contest
    • Stick It! Contest
      Stick It! Contest
    • Casting Contest
      Casting Contest
    Cool!
    How much further does it shoot with this mod?
