*DISCLAIMER* I am not responsible for any damages, lawsuits or injuries for possessing a realistic weapon so obviously don't bring this thing out in public. I am also not responsible for any damages done to your Recon. If you follow the steps correctly there should be no issues (left over parts are always bad). If you have any questions just PM me or drop me a comment and I'll get back to you A.S.A.P.
Remove these ads by
Signing UpStep 1: Materials and tools
-Nerf Recon Cs6
-Nerf Flip Clip
-Rustoliem Universal All Surface Spray Paint : Flat Black
-About 2' Of 3/4" Copper Pipe
-220 Grit Sand Paper
-Nerf Raider Or Soaker Wars Shotblast Stock
-Screwdriver Or Multi -Tool
-Pipe Cutters(not shown)
-Plastic Bags(the small ones)
-Reauseable Divded Plastic Container
-Permanant Marker
-Q-Tip
-Hockey Tape
-A Hard Dry Clean Work Surface
-Sunglasses(just if you want to look cool and i'm sure we all do)
Visit Our Store »
Go Pro Today »
When you place the 3/4" copper pipe in the original barrel it sholud slide freely. I used hockey tape (shown in the last step) to hold the copper pipe inside the plastic barrel.
The original plastic barrel remains inside the hanguard the whole time.
m4a1-i used another cs6 barrel inside the outter pipe to make the the extended barrel,the scope is a red dot sight that i bought off ebay,(YOU CANT SEE THE STOCK)its a raider stock
m203 grenade launcher(FRAME)-the barrel is a nerf ebf25 barrel,nerf ebf25 side rail to hold the barrel and space it from the cs6 rail,and yes i used some card paper for the trigger assmbly
-blueblobbs
i have the gun but its to complecated
Also, In the Step 2 do I have to unscrew all the screws and then insert the copper pipe or measure it then remove it?
Another question, I have a 1.5M 19.05 X 1.02 Copper STR Length Pipe.
It doesn't seem to fit in the hole with all the screws together.
(I don't live in the usa so My resources may be limited but please correct everything you can.)
If you could answer all these could you also tell me if there's a video tutorial?
In step 2 you do not need to remove the screws right away. You must connect the barrel to the gun and slide in the pipe untill you feel resistance from the bolt.
The copper pipe has a 3/4" internal diameter I found it in the plumbing section of my local home hardware (if they have that were you are). 1.5M 19.05 X 1.02 Copper STR Length Pipe? from what I know STR piping is plastic. All you need is a normal 3/4" ID pipe.
Bring the inner barrel and a dart to a plumbing/hardware store and if there is a small space between the pipe and inner barrel your fine (don't forget to make sure if the dart fits).
I live in Canada but plumbing and lumber products are still mesuredr using the imperial system so really I cant help you much.
By the way....Thanks for the help...
I have a question though the silencer uses pvc will that work on the pipe in this one?
I looked and no useable pipes and dad won't let me use his spraypaint
BEAUTIFUL
It also works with normal 3/4" pvc, the pvc slides over the other barrel though and requires minor cutting or the barrel attachment
This is THE single best instructable ever
the darts keep getting stuck mid barrel, any tips on fixing it?
