Nerf Scope Attachment Mod
31,011
18
7
Published
Introduction: Nerf Scope Attachment Mod
About: Find my stuff at Nerfhaven.com; username Shanaynay.
This is a fairly simple Nerf mod to make a scope attachment that clicks onto a rail. And to note, this is a scope with zoom, not an ACOG sight like the one that comes with the Longshot. Also, I made this first, then made the Instructable; because of this some things may not be as in depth picture-wise or as accurate.
I've tested my "arsenal" of Nerf guns, and found that the scope works best with the Maverick and the Barricade guns.
Items/Tools:
-Cheap Toy Binoculars
-Nerf Rail Clip (I used the flip up sights from the Recon)
-Hot Glue Gun and/or Duck Tape (hot glue strongly commended over duct tape)
Depending on Rail clip and Binoculars:
-Screwdriver
-Possibly a utility knife or hacksaw
Step 1: Disassemble Binoculars and Rail Clip
Binoculars:
I was lucky and found my binocular scope already disassembled from the other part of the binoculars, so you will have to figure out how to unscrew or cut off one of the sides of the binoculars on your own. save the half that doesn't have that middle part attached (thing that regulates focus/holds them together). This obviously will become the scope part.
Flip Up Sight:
Again, doesn't have to be flip up sight, you can use another similar attachment's rail clip if you would like. however, I prefer you use the flip up if you have it since it looks good with the mod, as well as the point that the flip up on its own is completely useless and doesn't work (might as well find a use for its parts). So, either yank off or cut off the black flip up part so that only the yellow body and black rail clip parts remain. That was easy.
Step 2: Glueing (or Taping)!
So like I said, I strongly recommend using hot glue for this rather than duct tape. Hot glue actually makes it more secure and I think it looks much cleaner.
NOTE: I did this the first time; MAKE SURE YOU DON'T GLUE IT ON BACKWARDS! It's easy to forget really.
Once you get your sense of direction, find a good spot where your monocular? fits relatively well or interlocks. DRENCH the bottom of the scope in hot glue, then stick it directly into the desired place. Once that batch hardens, try to cram some more hot glue into extra holes or concealed areas to guarantee a strong bind.
Step 3: Trial
Congrats! You (hopefully) successfully created a scope for a Nerf gun! Go try it out and see how it works.
Since un-modded Nerf gun typically dont shoot horizontally very far, the scope wont be great for all guns, but is a great replacement for guns that use ACOG. So rather than ranting on how this doesn't make you the COD sniper you want to be, be grateful you have a replacement for the sucky stock ACOGs Nerf makes.
Thanks for looking. This is my first instructable, so I appreciate any feedback or questions.
I'll be making an instructable on how to make a Nerf wrist rocket concealable nerf gun mod later.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Stick It! Contest
      Stick It! Contest
    7 Comments
    If it's modded to heck, (75ft+ ranges) then absolutely!
    This would be really nice for my 220V Hail-Fire. Or should I say...
    Hell-Fire
    In my grandparents basement. If you have no toy binoculars at your house from you or younger siblings, then just go to a toy or dollar store and pick up some cheap ones. I just got lucky and got a pair that were yellow and fit well.
    were did you get the bionaclurs?
