Nerf Singled Sledgefire Shell
3,070
6
Posted
Introduction: Nerf Singled Sledgefire Shell
This is a mod for a nerf sledgefire shell that will allow it to fire one dart instead of 3. This increases range because the sledgefire has a lot of power to propel 3 darts, but by doing this, you are putting all that power behind one dart, shooting it much further. This makes the gun more like a sniper, giving more versatility.
Step 1: Preparing Your Shell
For this step, use a cutting wheel on a dremel, and cut down the sides as demonstrated in the pictures. Don't cut out the very bottom! This will get the shell ready for the cpvc barrel.
Step 2: Adding the Cpvc
Once you have gone to town on that shell, get out the middle. This will take some patience and fine tuning, and don't rush, because you could damage your shell. Next, on the bottom, there will be some annoying bits that will prevent the cpvc from fitting. Sand those down until you can fit some cpvc in.
Step 3: Securing the Barrel
For this, make sure your barrel is centered. Then, load it with hot glue until it is secure. With all that glue, it may become hard to fit into your sledgefire barrel. Because of this, figure out where you points of friction are and sand them down until you can put in and remove the shell like you could with a stock shell.
Step 4: Conclusion
By doing this mod, you should have a more useful shell, and be able to use the sledgefire a bit more. Thank you for reading, feel free to comment, and good luck!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
3 Comments
Hey how does the air go to the dart if the dart is placed in the middle of the three air restrictors?
This is a very interesting idea but couldn't this put strain on the blaster?
How would this put strain on the blaster? Firing one dart isn't going to do any harm, even if it goes further. It simply puts more power behind one dart, instead of less behind 3 darts.
