Step 4Construct Barrel
Glue a 1/2 male adaptor to your barrel. This will screw into the assembly we just created.
Now duck tape together your two 1/2 couplings. Then drill them out so the fit easily over your barrel.
Using a dremel or drill create a gap large enough at the bottom of the barrel so you can load the darts directly into the bottom without using a ramrod. I put two hose rubber thingers on either side so no extra air can get out.
You use the coupling to slide over the gap you created while shooting.
comment
Add Comment
Add Comment
