loading
Step 3: Take the Vulcan Apart
  • Use a claw hammer, to pry off the bolt head.
  • Remove the battery tray cover, as well as the battery tray.
    • Depending on the age of your Vulcan, there might be a sticker.
    • If there is a sticker, you will then have to cut it in half.
  • Now remove all the screws from the main part of the blaster.
    • You don’t need to take the screws off which hold the barrel together unless you plan on painting the blaster.
  • Carefully pry the pieces apart.
  • Be careful that you don’t damage the wires.
Hey is it possible to use the gun with just the arduino
<p>Our WiFi / Internet Enabled Sentry Gun with Android App. Built using your Instructable, then we wrote our own code. Thanks! <b style="">http://tinyurl.com/jkul8an </b></p>
<p>Hi Britt,</p><p>I'm trying to recreate this project with a nerf stampede and having trouble with the motor. I've only taken the gun apart so far and the motor's size and shape is very similar, but the circuit attached on top is different. How would the wiring be any different?</p>
<p>Hi, I am sorry, I don't know. Sadly I don't have one, so I can't check it out.</p>
<p>Almost completed software working and tested with the servos just have to get some brackets and something to use as a stand then counterweight it and we are done</p>
<p>I am sorry, I missed your comment. Great job! Thanks a lot for posting pictures!</p>
<p>nice and creative </p>
<p>Do you think this would work with a Nerf Rhino? </p>
<p>Maybe if you take it apart, else it is probably to heavy.</p>
<p><a href="http://www.amazon.com/gp/product/B002BBFDI0?keywords=ball-bearing%2012x28x8&qid=1455262144&ref_=sr_1_1&sr=8-1" rel="nofollow">http://www.amazon.com/gp/product/B002BBFDI0?keywor...</a></p><p>would these be the type of ball-bearings used? and where are they placed? in the shaft for the vertical movement i assume?</p>
<p>wow.. This looks very good! Keep up the good work! :)</p>
<p>you can get the spring here</p><p><a href="https://blastersmiths.co.uk/products/6kg-vulcan-slash-triad-spring" rel="nofollow">https://blastersmiths.co.uk/products/6kg-vulcan-sl...</a></p>
Can i use some other motors like geared dc motors rather than using a servo motor? Britt please help me
<p>Yes, but you will have to figure out a way for it to know in which position it is.</p>
I don't understand why is it important for the motor to know in which position it is and like you have coded such that the turret won't fire at the logo.where can we edit it so we can make it fire at desired logos
Let me correct myself, the tracking and recognition code.
Hey, I was wondering if you could possibly give me the standalone code for the logo recognition? I can't find it, and I'd like to change it to something other than an instructables logo.
Hi brittlv I'm a personal shopper and wanted to buy above for my clients kids do you sell mod nerf pieces ? Do you have an email address I can reach you on ?
<p>Hi, I am really sorry, I don't sell the parts. I have been thinking a long time to build a new version, but so far haven't gotten around to it. </p>
@BrittLiv is there any way a wireless connection could be established between the arduino microcontroller and the computer?
<p>You can try using a Wi-Fi module for the arduino.</p>
<p>*builds sentry* &quot;Sentry, goin' up!&quot;</p><p> - Engineer, Team Fortress 2.</p>
<p>what would I take out of the arduino code for controlling the gun with just the game controller.</p>
<p>Hi, lads! Me and my buddies make a cool nerf shootout video. Do you like it?</p><p>http://www.youtube.com/watch?v=jkHsyAg_3Bw</p>
<p>You don't suppose that there is a way to use a phone instead of a computer? A phone can interact with an arduino via the usb. Iv'e been googling around and have not found anything about using a phone as a sentry gun controller. (After all, who wants to use a bulky pc when they could use a phone which is way smaller, and has a built in camera?)</p>
<p>you could attempt at using raspberry pi, or banana pi for more power. If you can get the software on Linux, shoot for it, other wise you may have to install windows on it. That could easily fit in the casing.</p>
You missed my point. I asked if there was a way to use a phone instead of a pc.
<p>Here is how you control it with your phone. install processing on a raspberry pi (scruss.com/blog/2014/01/07/processing-2-1-oracle-java-raspberry-pi-serial-arduino-☺/) from there install a wireless wifi module on the pi and set up an ad-hoc network between your phone and the pi. install vnc server on the pi and a vnc viewer on your phone. run the processing script from the pi and it should be viewable on your phone after you connect to it via vnc.</p>
<p>...what does all that mean</p><p>o_O</p>
<p>yeah yeah, I see. I don't know about that, but I was giving you some extra options..</p>
<p>Im having some trouble with the wiring... can someone or @BrittLiv send me some pictures of the breadboard wiring... </p>
<p>The first image at step 10 doesn't help?</p>
<p>i cant properly see the connection. when i hooked it up it only fired.. the programs and stuff are working fine. Could you possibly email me a better pic or post one? PLease.. THANKS!</p>
did you ever figure this problem out, because I am running into the same thing! my gun is complete, the programming is functioning correctly but only firing...
<p>Could you do this with a nerf stampede? </p>
<p>Hi, I'm on step 5, just waiting for my soldering iron to get here, but I need to ask, would this still work on A linux based OS? Or is Windows required? And if I can use Linux, how would I go through doing that?</p>
Use a punisher minigun.
AWESOME
Hi, I am hoping you can help me here with some clarification on the trigger circuit. I have followed everything yet everytime I connect the power I end up melting part of my breadboard! Can you upload your fritzing diagram?
I tried to make a remote sniper on this basis. <br>I need a mega centurion tho.
Any other servos that are cheaper?
<p>when I run the program it says the package &quot;org.apache.commons&quot; dose not exist. might be missing a library. please help.</p>
<p>Why is there a yellow wire after the diode. I must be reading it wrong but it seems to lead to no ware nowhere.</p>
<p>Sorry. But what WATT 1k resistor did you use. The pics are to small for me to tell.</p>
<p>Hi I live in the usa and you cant buy wood in metric sizes. If I still use the Axial ball bearing (80 x 105 x 19 mm) but wood in sizes like 1/4&quot; 5/8&quot; and 3/8&quot; Will this work? I am worried the servo will sit too high or low inside the axial bearing. Thank you so much. </p>
<p>I'm considering starting this awesome instructible, but is replacing the spring a must? Would I be able to build the sentry gun while keeping the fire rate normal?</p>
<p>The stonger spring will allow the darts to fly far-er and faster, but no it is not a must. I have seen some people add a few coins and the like behind the spring so as to have the spring be more compressed. </p>
<p>i can't find m4 40mm and 16 mm screws. It might be better if the screw were m6 instead. Is it ok to replace m4s wtih m6 screws?</p>
<p>I have taken on teaching myself and completing some extremely involved and complicated projects, but this one, whew! I can't wait until I get up to speed on the electronics, then the arduino. The complexity alone isn't the only fantastic characteristic, the instructions seem extremely comprehensive. Once I am, this will be my first project. Amazing!</p>
About This Instructable
397,165views
1,293favorites
License:
Bio: Hi, my name is Britt Michelsen, I'm a Chemical Engineer especially interested in Computational Fluid Dynamics. To balance all the theoretical work I like ... More »
More by BrittLiv:Minion Fart and Smoke Alarm Thor's Hammer Toilet Brush Harley Quinn Baseball Bat Pepper Mill
Add instructable to:
