3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Nerf grenade launcher (homemade)
Ammo
3 foam balls (only shoots 2)
or
3 velcro darts
Ranges 5-10 feet
46 comments
1-40 of 46next »
Feb 14, 2012. 12:45 AMewak says:
what are the material?
Jan 26, 2012. 5:15 PMAttmos says:
nice, i like it.
Nov 23, 2011. 4:14 PMS P A R T A says:
I just recently built something similar to this. My Nightfinder broke after a failed mod, so I took the plunger tube (I think it's called, just that orange tube with the spring in it) from the Nightfinder with the full plunger assembly, and sawed off everything other than the handle past the front of the huge circle with the Nerf logo on it. The plunger assembly goes into it, and there is a small rectangle there, just glue the plunger tube to the end of the Nightfinder, pull the cocking mechanism, it should lock, then press that button. Watch your fingers, I learned that the hard way. I can fit 3-4 darts in, but it doesn't go as far as 2 darts.
Feb 21, 2011. 3:55 PMMatrix-technician says:
Make an "ible for this launcher please! I've been looking for an underbarrel launcher "ible".
Jul 24, 2011. 8:25 PMatomiclegocreations says:
look up Meanbean's Nerf grenade launcher and make one. To put onto the barrel, you should get some PVC pipe and cut it to just the right size, then, take that scope you get with the recon, and take out the innards. You should get the rail piece. Hot glue the PVC pipe to that.
Mar 7, 2009. 7:47 PMGiggidygoo4u says:
One day nerf is gonna start making the next M4 for our military. And it going to look FREAKIN AWSOME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sep 15, 2010. 1:25 AMV1nz0rd says:
but, the M4 will be bright yellow and the enemies will alwas be able to see our troops. and they'll shoot darts instead of bullets. LOL!
Mar 7, 2011. 7:39 PMkve23 says:
poison darts >=)
Feb 12, 2011. 6:33 AMRoyse9808 says:
that's awsome but how does it shot?
Jan 13, 2011. 6:34 PMBlue Mullet says:
Cool!
Sep 14, 2009. 9:09 AMaseaheru says:
1, HOW DID YOU MOD THAT LONGSHOT!!!!!!!!!!!!!!!!!!!!!!!!! 2, how do you make this 3, co2/ better spring? am gessing uses spring
Nov 12, 2009. 9:54 AMaseaheru says:
mag+site
Nov 19, 2009. 7:29 AMaseaheru says:
sweet. merf now makes clips that you can attach 2 mags to.
Jan 25, 2010. 10:48 AMaseaheru says:
ack
Dec 7, 2009. 6:09 AMaseaheru says:
glue between clips and clip clip
Jul 22, 2010. 3:34 AMV1nz0rd says:
pretty sure you should just duct tape the clips together.
Aug 18, 2010. 9:13 PMaseaheru says:
makes sence, but take falls apart and plastic cement holds together
Sep 15, 2010. 1:22 AMV1nz0rd says:
maybe, but even if it does, you can just re- tape tape it. I keep a spare roll of duct tape in my bag for emergencies.
Sep 21, 2010. 4:51 PMaseaheru says:
ok, i can see that
Sep 15, 2009. 8:55 AMaseaheru says:
EVERY THING! fore my #1 ...??????
Sep 16, 2009. 8:44 AMnashua25 says:
this is really good, i'm suprized that people have'nt thought of this before.
Aug 26, 2009. 7:02 PMmeanbean says:
5 to 10 feet? really, you could throw those balls farther than that. Get it to at least 20 feet using spring mods, and a new o ring, then cram like 5 in there. now THAt would work.
Aug 24, 2009. 9:46 PM1129ag says:
how did you make that
Aug 20, 2009. 8:11 AMColonel88 says:
ehh it doesn't look like it has "mad" range, consider modding a Atom blaster into it instead of a nitefinder since atom is MEANT for shooting those little balls
Aug 9, 2009. 11:02 AMbeastie21 says:
how do u make it???
Jul 25, 2009. 6:42 PMNerf S.A.S. says:
put up an instructable for this
Jul 10, 2009. 12:48 PMGeoff 117 says:
Can you make an instructable showing how to make a longshot like yours?
Apr 22, 2009. 3:03 PMemuostrich says:
Looks aren't all. And judging from the 1(one) picture you most generously gave us, I don't see much point in making it. If you can get an astounding 5-10 feet out of it, just go take a nickel and by yourself a Reactor. And if you care about putting the hurt on, just buy a BBBB (Buzz Bee Big Blast), do a barrel replacement, and make some stefans. Oh, and if you're going to make a double clip, couldn't you just take the time and effort to make one that doesn't require you to take it out and flip it? CS's 12-dart LS clip: http://nerfhaven.com/forums/index.php?showtopic=8071 And this is to everyone (not just you...) If you have the time to glue two LongShot clips together, you have the time to join my site at http://www.theinnercore.webs.com, and especially if you used epoxy. Remember, join now or you won't get the valuable incentive. And by "now" I mean NOW.
Mar 29, 2009. 8:24 AMtoogers says:
hmmmm..... nice but it looks kinda flimsy, like i'ts gonna explode from the pressure of the spring.
Mar 19, 2009. 3:50 PMclemsonguy1125 says:
make a instructable
Mar 23, 2009. 1:38 PMMaDDDOGHEAD says:
serouisly think about making an instructsble
Feb 1, 2009. 5:57 AMknexsuperbuilderfreak says:
wow thats neet! how does it attac to the gun?
1-40 of 46next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
40
Author:maxxxem
