Introduction: Nerf Gun Nite Finder Mod
modify a nite finder nerf gun so you can hold the lite on with out accidentially firing.
Step 1: Materials
You need a drill or remer, a momentary switch, a nite finder nerf gun, a screw driver, some wire, adn a soldering iron(i just twisted the wires cause i dont have a soldering iron)
Step 2: OPENING THE GUN
Unscrew the case, make sure you dont lose the screws
Step 3: Removing the Old Switch
Cut the wires to the old switch. solder or twist new wires long enough to reach placement of new switch.
Step 4: Drill New Hole
Drill or ream a new hole for the momentary switch. placement doesnt matter as long as it fits.
Step 5: ATTACH AND WIRE THE MOMENTARY
Insert the switch into the hole and put the bolt over the top to lock it in place. Then wire the light to the switch
Step 6: REATTACH THE COVER AND YOU ARE DONE
Screw on the cover and you are done
