Nerf Gun Pistol Mod
6,039
13
8
Published
Introduction: Nerf Gun Pistol Mod
So This is a nerf gun witch I have modded to shoot 9 times as far!!!You all probably know this mod but I was bored so I made an ible on it!!!
This isn't really an amazing mod as everyone probably knows it.
What you will need:
A stretchy elastic band or two.
A nerf gun pistol with a pull back
Step 1: The Elastic Band
So for this mod you will need an elastic band. You can just use a regular postman band or you could use a thick one like me. If your band aren't long enough then you will need to tie them together.
1-Place the two bands so that they are overlapping each other.
2-Pull the end of the band on the top under the edge of the band on the bottom.
3-pull the end that you have put under the other band back up through the loop and pull tight.
If you don't understand then look at the pictures.
Step 2: Done!!!
now all that you have to do is loop it around the bottom of the barrel and around the draw back then you are done!!!
#>>>>WARNING <<<<#
If you put to many bands on the drawback can snap!!!
    • Microcontroller Contest
    • Flowers Challenge
      Flowers Challenge
    • Outdoor Fitness Challenge
    8 Comments
    nice work but it won't shoot 6 times farther. you would have to mod the nerf Mega centurion to get that far.
    Very nice instructable, But you should try putting the rubber band in the middle front of the gun, so that the tension is not upward, but straight on.- That would greatly reduce the chance of the plunder rod of snapping.
    cool :D a gun with 'happines' around it :P
    Wow I am amazed at how much this improves the gun!!!
    ThanX i am planning on making alot more like it!!!
