3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Nerf longshot .50 cal
this is my longshot. it took me about 2 days to modify and paint it. the mods i did were doubling up the spring with a recon spring, removed both Ar's, and i took out all the safteys. oh and it is about 4 feet long with the extended barrel.
27 comments
Feb 5, 2011. 12:50 PMDarthscout says:
it doesn't really look to much like Barret .50. you could make a muzzle brake. But that might be a little hard. GOOD JOB OVER ALL
Apr 17, 2012. 9:38 AMMSgt_JGC says:
well my friend, "Barret .50." that's vague isn't it?
because Barret makes lots of different firearms, you might be thinking of the M107 or m82A3
May 28, 2012. 4:58 AMrfahlevi says:
yes very true indeed..but this m82 has no muzzle brake soo this is more of the m82a1 ;)
Nov 23, 2011. 6:02 PMSupabuild111 says:
This may be an old post but get off your xbox and look at this http://bit.ly/rr8CWa your precious Barrett isn't the only thing in the world
Dec 11, 2011. 5:00 PMDarthscout says:
i don't have and xbox or ps3 okay?! i don't really like video games. i'd rather get out and play paintball...
Jun 20, 2011. 11:01 PMCapt. Kidd says:
When you say "Flash muzzel thingy", do you mean the muzzle brake?
Apr 17, 2012. 9:37 AMMSgt_JGC says:
It looks like a flash suppressor.
Feb 26, 2012. 7:46 PMmotomax99 says:
i think he meant flash supressor
Mar 19, 2011. 11:13 AMmrelement says:
What are the spring specifications?
Nov 21, 2010. 7:26 AMHitman227 says:
How did you take the clips apart to paint them? I tryed but the tops are glued shut.
Nov 29, 2010. 4:39 PMHitman227 says:
Okay... I was getting worryed there. Check out my recon m16/m4 cosmetic mod. d:)
Feb 20, 2011. 12:27 PMnatester632 says:
ur supposed to take the apart, take out the 2 screws, and take one of those little tabs that are holding it together and just kind of pry it up, but make sure it doesnt break
Mar 5, 2011. 4:21 PMHitman227 says:
Already done.
Feb 23, 2011. 5:58 AMkve23 says:
what size pipe did you use?
Aug 31, 2010. 9:52 PMlazyboy13 says:
it doesnt really look like a 50 caliber rifle. try using a copper pipe instead of pvc cause the dart goes out faster cause it doesnt rub against the barrel. i tried it and it works great! good attempt tho. :):):):)
Nov 23, 2010. 4:37 AMHitman227 says:
You should use 3/4" unless your rifle is very powerful
Nov 13, 2010. 9:05 PMNoah4all says:
I've been moding nerf guns for a lil bit now and I've learnd a few things and first don't use copper for your barrel it would cost so so much for a lil bit and second you should use PETG you can't buy it at hardware stores but go to nerfhaven and there should be sellers there and then ou nest in your PVC an the second thing is just using Cpvc (you can find that at almost any hardwhere store) it's bout as cheap as PVC
Nov 23, 2010. 4:36 AMHitman227 says:
I use copper. For me I only need 2' so it costs me like 3$.
Aug 28, 2010. 7:03 AMmr.incredible says:
Looks nice but does it work? How far does it shoot? What is the accuracy? You neglected to state the most important parts. Need video proof.
Aug 28, 2010. 7:51 PMdarknessfalls says:
willing to bet the distance is way down due to the elongated barrel
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:eman414
