Nerf nightfinder bb gun
 by Bajamini
This instructable will tell how to make a bb gun out of the nightfinder.
Step 1:
You have to remove the air restrictor and add lots of rubber bands.
Step 2:
You also need this 1x1 lego pillar.
Step 3:
Use the copper bb's. (not airsoft)
Step 4:
Remove the rubber head and stalk from a dart and insert the lego pillar with the square part sticking out.
Step 5:
Put it in the gun and tape it so it can't fall out.
Step 6:
Now you have a rather powerful nerf bb gun. If anyone can improve the accuracy please let me know because it has really bad aim.
vertex21 says: Apr 20, 2009. 2:35 PM
Make the barrel longer to improve accuracy this will unfortunately takeoff a bit of power
mlking21 in reply to vertex21Feb 18, 2010. 10:00 PM
 he already said that this gun had lots of power, so I think it wouldn't really matter but it will be hard to make a straight barrel (if you know what I mean). A fact about the power: I don't think you need so much power that you can go down the street shotting people down =P.
daggerofblood1243 in reply to mlking21May 13, 2012. 9:21 PM
Shotting poeple down?????!!!????
viraj_13 says: Nov 27, 2009. 6:19 PM
 can i use a pen... like this part anyway..
35Timmy in reply to viraj_13Oct 8, 2011. 6:11 AM
why yes i am not sure about this kind of nerf gun thou however you do not need the cap what i do is i remove the straw of the nerf gun and put in a pen tube then you can insert a bb and you can poke in it with a ink all thou somone times you have to untape it a poke it out with an ink tube and even more rare sometimes you have you etrher pull out the bb or cut the bb out if you cannot press it out also be carefull i am not reponsible for what you do with this i have my own repononsiblitys now the only problum with that is you have to open up the nerf gun you can also use other brands PLEASE FOLLOW THE COPYRIGHT GUIDELINES
35Timmy in reply to viraj_13Oct 8, 2011. 6:09 AM
viraj_13 in reply to viraj_13Nov 27, 2009. 6:20 PM
 only the white part
35Timmy in reply to viraj_13Oct 8, 2011. 6:12 AM
well the pen tube will be the air gun barrel but i advise you use the ink tube to stick in the bbs
strcrusher in reply to viraj_13Feb 17, 2010. 3:43 PM
ya you can use that
but put lots of tape on the back so it fits
35Timmy in reply to strcrusherOct 8, 2011. 6:23 AM
yeah use tape so it secure also you do not need the spring unless you go into replacing a spring whitch you can lookup on instructables search bar
BADWOLF1 says: May 7, 2009. 6:25 AM
where do the bbs shoot out of the gun
soldeir 9 in reply to BADWOLF1Jul 4, 2011. 12:02 PM
at the back so it shoots u in the face lol jk
firefighter1333 in reply to BADWOLF1May 7, 2009. 7:21 AM
i think out of the front ×D
viraj_13 says: Nov 27, 2009. 6:16 PM
 can't you think of anything else
opinion thats mostly true--- I dont think that a lot of people have lego pillars
dombeef in reply to viraj_13May 15, 2011. 3:43 PM
A pen barrel
I used that before it was taken away...
ThaAWESOMEducttapeguy says: May 7, 2011. 4:29 AM
u dont rly need th rubber bands, its powerful enuf alrdy
ThaAWESOMEducttapeguy says: May 7, 2011. 2:09 AM
HoW dO yOu RemOve thE aIr ReStrIctOr???????
akak1559 says: Apr 9, 2011. 10:50 PM
how do u remove the air restrictor?
charlie.nourse says: Nov 4, 2010. 6:14 PM
Try using a bic pen body instead of a lego pillar.
legomaster50 says: Apr 27, 2010. 12:37 PM
whats a lego pillar?
Jugglebug says: Nov 1, 2009. 4:37 AM
For accuracy lengthen the barrel with a piece of 1/2" inch pvc- or alternatively change the way you make the barrel smaller and use a pvc size appropriate for the bb's you are going to use.
hikarusant says: Aug 26, 2009. 3:26 AM
hikarusant says: Aug 26, 2009. 3:25 AM
The air restrictor or what i think is the long cross piece in the middle when you open the tube that shoots the dart.
footbagboi says: May 17, 2009. 11:37 AM
okay bajamini, no offense, but this gun sucks. the bullet just falls out of the barrel
Zaphod Beeblebrox in reply to footbagboiMay 23, 2009. 7:09 AM
I did this with more rubber bands and an airsoft barrel and it was insane!!!!!!!!!!!!!!!
footbagboi in reply to Zaphod BeeblebroxAug 24, 2009. 3:01 PM
haha well good for you
li789 says: Jul 22, 2009. 6:31 PM
where are the are the air restricters exactly
bigskinsfanj says: May 25, 2009. 4:10 PM
No offense but this gun sux it wont even go anywhere it just falls out of the barrel and then my friend ate the gun sooooooooo yeah
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
