Nespresso Bluebells
2,707
19
5
Posted in HomeDecorating
Introduction: Nespresso Bluebells
About: Gat-toothed, self-employed artist, paper folding ninja, travelling badge purveyor
These coffee pods make surprisingly realistic bluebells, as well as making a pleasing bell like sound.
Step 1: Cleaning the Pods Out
Nespresso pods are an interesting material. It's very light, easy to work with, beautifully coloured metal, but to get that metal involves messing about with used pods.
I'm not wearing gloves in any photos, but you might find it useful to do so. I did end up getting very small cuts a bit like paper cuts, but they weren't painful.
Step 2: Getting the Coffee Out
Cut the top off using sharp scissors. I'm using an old pair of nail scissors, but anything will do, as long as you don't mind getting coffee on them.
Peel away the top. It's a bit like a yoghurt pot lid, and will come off in small pieces and be very irritating!
Tap upside down into a bag, and wipe around to get most of it out.
Step 3: Washing the Pods
This is what an empty pod looks like.
To wash them, I simply put them in the sink in some water for a bit to soak off the stubborn bits.
Step 4: Drying the Pods
Using a piece of tissue, dry each one individually. There is a kind of filter in the bottom of the pod, and leaving it to dry naturally can make them smell.
Step 5: Kit for Making Bluebells
You will need the following:
  1. Washed out nespresso pods
  2. thin florist wire - 15cm is perfect.
  3. a long piece of thick wire (not shown in picture) - 30cm is perfect
  4. floristry tape
  5. beads
  6. pliers
  7. an awl (or similar)
  8. scissors
Step 6: Shaping the Pod
Using pliers, press around the edge of the pod and flatten to make the pod into a bell shape.
Step 7: Making a Hole
To make a hole in the bottom of the pod, put the pod flat onto a cutting board (or just a piece of scrap card or wood) and push the awl through carefully in the centre. The metal is really thin and it doesn't take much pressure.
Step 8: Putting in the Bead
Take a bead and a piece of thin wire. Thread the bead onto the wire, and bend the wire in half so the bead is on the fold. Push the free ends through the hole in the pod, then twist the wire to keep the bead and pod in place.
Step 9: Making the Stem
Wrap floristy tape around the wire, paying attention to where the wire joins the pod. Cover the length if wire in tape, making it a bit thicker where it meets the pod. You should still be able to bend the wire.
Step 10: Attaching the Bells
Once you have made a few of these, attach them to one end of the thick piece of wire.
Wrap the thin wire around the thick wire until it is secure. Attach a few close to each other all at one end.
Step 11: Finishing Off
Once you have enough bells added to the thick wire, you will need to wrap more florist tape around the thick wire to strengthen the structure.
You will need to weave floristry tape in and out between the bells, and it is a bit tricky, but it's worth it for a stronger finish and it looks more like a real flower too.
Step 12: The Finished Flower!
The final thing should be bent slightly when displayed so the bells hang in a realistic way.
    • Spotless Contest
      Spotless Contest
    • Make it Move Contest
    5 Comments
    It's so pretty! That is an awesome use for those left over pods, I've heard so many people gripe about feeling bad about throwing them away. Thanks for sharing!
    Thank you! It came about because a friend said he had to take them to a nespresso shop for recycling and it was so far away the petrol he used offset any recycling!
    If there is one in your area, Sur la Table does accept the pods for recycling.
    This is great! I never would have seen a bluebell in one of those used pods, but now I'll see a flower in every one.
    Thank you so much! As I was washing them out, all I could see were bells :) I'll be uploading another instructable using them later, so keep an eye out :)
