This is my Braun 5510 shaver with rechargeable batteries. The batteries no longer hold a charge. It is possible to use the shaver with the AC cord normally used for charging. I wanted to replace the NiCad AA batteries with new cells.
Step 1Opening the case
The first problem is how to open the case of the shaver. This graphic from the shaver's manual gives some description. But, these instructions assume you will no longer use the shaver after opening to remove the old batteries for recycling. The seal is green as shown. Use a larger coin to push and break the seal. Then rotate the round fitting where the cord attaches counterclockwise about 45 degrees. Rotating this cord jack fitting required considerable force. I had to grasp a US quarter dollar with a pair of pliers to apply enough force.
Elsewhere I found instructions for a better way of opening the razor: undo the screws at the top, then pull it apart until you can use a long screwdriver to move the plastic lug (held by a spring) visible at the bottom sideways. The lug has a catch on it that holds it in position for reassembly.
The picture looks the same, but mine is a 2450. I am guessing that the technique I used will not work for the 5510?
It was immediately after doing this project that I went to replace the NiCad cells and learned they were no longer in stores available to me (Radio Shack, Batteries Plus). The folks at Batteries Plus suggested simply using NiMH cells as substitutes for NiCad cells. That surprised me, based on what I had read up to the present. I have not tried it yet, though.
Thanks for your comment.
I just learned that someone used a set of 1650 mAh NiMH 1.2v batteries in their shaver and they worked out fine. I'm going to go with the 2200 mAh ones; it'll be interesting if the shaving time is extended between charges over OEM performance. Maybe I'll do a writeup of replacing the cells in the 7000 series. :-)
So, I plugged in the shaver and let it go through a charging cycle (60 minutes). When the flashing light went off, I disengaged the shaver from the cord, then tried to operate it. DEAD. I plugged it back in and tried to run the shaver, and it did work. It just won't run off the cells. I double checked the circuit again and it showed OK--the batteries are fully charged. I suspect that something must have gone wrong on the circuit board. The only thing I can think of is that it isn't designed to handle a 1.2v battery that has a 2300mAh rating. I quite sure I didn't introduce any issues directly (e.g. short or broken circuit).
It doesn't match the description/picture above. The charger plug isn't round so doesn't turn/unscrew.
Yes, the 7526 is a different model; this instructable is based on a 6000 series shaver. The bottom socket surround is rectangular, with a protrusion in the center where you insert the cord. To remove the surround, or "plug", you insert a small screwdriver just within the lip of it (so you are getting leverage on the plastic). You then apply pressure to pry the surround off. There are 4 little hooks that hold the surround on, pointing to the front and back panels of the shaver. So you want to pry in that direction for easier removal. Good luck!
My attempt to use 2200mAh and higher batteries failed miserably. The additional storage capability of the batteries seems to confuse the shaver firmware. As I had suspected might be the case, it is tuned to deal with a specific battery capacity. So, it's important to use batteries that are as close to the originals as possible. I believe the originals were more like 1400mAh or 1500mAh. 1650mAh is probably on the edge of tolerance for the shaver, and it probably doesn't give much more shaving time than a 1500mAh battery. I'd say it's best to stick as close to the original specs as possible.
