This is my trouble light, also known as a work light. It needed a new guard to protect the bulb. I decided to make my own, even though
I could have ordered one. My local hardware store did not have one, even though their parent company's web site shows some of their stores stock them. I also noticed some things about the conventional design of trouble light guards that have presented minor difficulties in use, and I wanted to correct those.
Materials-- Sheet metal from the outer cover of an old washing machine
1/8 inch steel rod (from concrete reinforcement wire stubs)
2 #8-32 machine screws and nuts
An old speaker magnet
Tools-- Flux core wire feed welder
Angle grinder with a cutting wheel
Dremel tool with cutting wheels and grinding stones
Vise
Electric hand drill and bit
Grinding wheel
Screwdriver
My trouble light is a cheap plastic unit that still works well, except for the broken guard. The grill was plastic and broke many years ago. I used a piece of coat hanger wire to make a protector for the bulb, but it easily pushes away and is little help. The old guard is also badly cracked. I never liked the swivel hook, either. It has never broken, but a twist in the cord will cause the light to turn away from the direction I want it to shine.
HNY,
Bill Drissel
I was just wondering if the inside had a more reflecting surface if that would have helped in any way, and maybe a low energy saving bulb.
Normally I don’t work with metal, but I was thinking how this could be done with wood which will be also more heat resistance. Just saying... like the challenge :)))
Add an LED bulb and it would be perfect!
Well done Phil, (as usual).
My trouble light guard has seen some better days, it's never been the same since it was backed over with a car I was working on
I've had rough service bulbs and they don't seem up for much more abuse than regular bulbs. Plus I've been burned by incandescent drop lights pretty good, I think that is why yours may have had a plastic shield. The metal shields get cooking hot!
I am wondering how a CFL bulb would perform in one of the old style holders. It might eliminate the delicate bulb syndrome, and would definitely stop the burn.
Now I want a cordless LED work light. I have some LED flashlights and I am impressed with how well they perform. I've seen LED work lights but haven't pulled the trigger on one yet, I should now though. There are some pretty tempting choices today. One of those would eliminate the last hassle with drop lights, the drop cord!
I like how you think though Phil, never let it die!
