(The book example is World Book Encyclopedia, 1989.)
Step 1: Parts Needed
Step 2: Assemble the camera mount
Step 3: Prepare the page-press
(My pressing pieces are 13 1/4” and my cross pieces are 13”, all cut as indicated relative to the adjustment marks on the tracks – see the second photo)
Use a file to smooth off the corners and edges.
(WARNING: Drilling round holes into the rectangular slots is not trivial and can be dangerous. Wear eye protection, hold the pieces in a vise, etc., etc. I found it easiest to first enlarge the slots by hammering in a tapered tool (a nail set), then drilling the holes.)
Step 4: Prepare the rods
Step 5: Final assembly
(The camera mount can go either vertically or horizontally.)
Mount the camera and check the alignment.
(Adjust the top, locked nuts as needed. Determine the best position for the nuts below the wingnuts, and lock them together.)
Step 6: Copy some documents
(The book examples are: World Book Encyclopedia, 1989, and The Butterflies of Cascadia, Robert Pyle, 2002.)
Step 7: Clean up the images (Optional)
- Rotate the image, if it is out of alignment.
- Crop the image.
- Adjust the brightness and contrast.
- Fix photo aberrations (e.g. pincushioning).
Step 8: Paste the images into one document (Optional)
Step 9: Convert the Word document into a Pdf file (Optional)
Step 10: Convert your Pdf files into word-searchable Pdf files
AND … You saved a few trees by going paperless! Thank you.
Visit Our Store »
Go Pro Today »
First of all, as has been mentioned already, you can buy the bookshelf track at Home Depot (and other places I'm sure). It was over in the cabinet section when I went. It costs less than $3 for a six-foot piece. It's pretty light and will bend if you treat it rough, but you can easily bend it back.
I found it to be impossible to drill a round hole in the rectangular slots of the track using a normal spiral drill bit. The bit kept getting locked in the slot, and that kind of stuff always makes me nervous. So just as an experiment, I grabbed an old spade bit (the flat ones used for boring large holes in wood) and gave it whirl. To my amazement, rather than killing me, this actually drilled round holes in rectangular slots like butter. I did about 80 holes in 45 minutes.
Here's what to do:
1) Place a scrap piece of wood underneath your track where you're going to drill. The track should be have the legs down, flat side up. Clamp the track down tightly near where you're going to drill so there won't be any vibration.
2) Insert a spade bit into your drill. You may end up dulling the bit so if you can use an old one instead of one from your nice new set, that would be good. If not, they're pretty cheap to buy. You're going to use the point of the spade to cut your holes, so the edges need to be sharp. The width of the base of the point should be slightly greater than the diameter of the hole you're trying to drill. I used a 1/2" spade for making the requisite 3/16" holes.
3) Insert the tip of the spade point directly in the middle of the slot you're going to drill and dig it into the wood to hold it in place. Start drilling at a moderately high rpm and slowly press down to ream out a hole about 3/16" in diameter. The edges of the spade point simple shave off the inside of the rectangular slot, and the hole will get bigger as you drill down further. It's the same idea as a step drill bit. The spade does such a great job of shaving off the soft track material that if your hole is off center or too small, you can just ream it out until it works.
4) Repeat as many times as necessary.
This technique will cause some minor variation in hole diameters because it depends on your ability to gauge how far down to drill. And it does leave some semi-sharp edges on the holes, but I think a single pass with a belt sander would take care of all of that. The process is amazingly safe, though. No chance of a bit getting stuck and torquing your drill or hurtling track across the room. I'd, of course, recommend wearing glasses, but I didn't see any metal shavings flying all over the place. They formed nice little piles right under each hole.
The bit itself lasted through 80 holes and didn't show any signs of getting dull. I'm sure there'd be no problem still using it on wood like it's actually designed for. I imagine the track material must have been aluminum or something else that's fairly soft. I highly doubt this would work at all with something made of steel.
I know this is only a minor thing, but I hope that it can prevent someone from getting stuck in the middle of the project like I thought I'd be.
How to convert pdf to word on mac
I'm will be adapting this for an iphone with the clariff case
Doing a book worked great. Here's the free OCR site I used:
http://www.free-ocr.com/
It wouldn't handle columns (I had to save pics as single columns of text before uploading), but otherwise did a very good job of recognizing my text. The text came up in a window on the screen (Firefox even underlined the misspelled words for me--not sure if that's built into the site or not) for me to edit & copy.
I haven't looked for myself, but read that this function is built into Google Docs now.
Yes, copying whole books you don't own is infringement, but there's been a long standing use of copy machines to duplicate sections in books for use at a later time, whether it's for school assignments, or just a cool project. This is especially true with reference books that the library doesn't allow to be checked out.
I mean if the library allowed it, then what would now allow you to use this in a bookstore?
If you did check it out, then you could just use a flatbed scanner.
Library books, magazines, etc. and items in a bookstore are not items you purchased, so you don't have any right to copy them!
The Copibook HD and we have one Copibook RGB+.
Your book scanner would be much better, if you could make the mount like on the copibook
However, in my work I have to copy large files of documents away from my office. I've been using a simple digital camera without a copy stand for years. It works very well. Much easier and faster than a photocopier.
Cheers
Mark
cool!
does this take a picture of the both pages at once?
Often you can take a picture of both pages. Check out the three different figures in step 6. In the first one, the camera is set up for two pages at once. Note that the camera can be either in the portrait (fig. 3) or landscape (figs.1, 2) orientation.
Copying portions regardless of method (and taking into account the use of the copies) is not a Copy Right infringement.
A digital camera is not a copier.... it is a camera. Sure a digital camera takes pictures like a copier, but a copier doesn't produce a file.
I liked the idea, though it is not an original idea. Good that people try to do and finish their projects. For my needs I would need two sided scanning (!) and a page turner/feeder, so personally, it is too nice (and time consuming to build) for small scanning and too simple for a 100-1000 page scanning. Personally, I just use "the hand stand" and even an old 2 mpix camera is OK to print it afterwards.
Fair use really only exists to let you something with the material - you can discuss it, criticise it, teach with it etc and that's fair use. It doesn't mean you can copy an entire book so you can read it on your phone.
You're right the DMCA doesn't really apply here but you're wrong to say that doesn't mean it's not against copyright. The DMCA is just one piece of US legislation. It's not all of copyright law.
A lot of things are against copyright law that you just don't get sued for, like copying music from a CD onto an iPod. It's a bit like jaywalking, it's technically a crime (copyright isn't a crime) but the police won't put you in jail for it because it's so minor.
That's why you're legally permitted to rip CDs and put the MP3s on your computer and mp3 players—but not upload those MP3s to peer-to-peer networks.
