New Knex Concepts (#6) Hammer Guns
Introduction: New Knex Concepts (#6) Hammer Guns
1: Hammer Gun 153: A gun that uses an elastic powered spinning mech to fire a rod. The rod is held in place by a mag pusher. In addition to the hammer, the spinning part has a short rod jutting from it that will strike the bullet when the trigger is pulled. This part also doubles as something for the trigger block to stop. The hammer should rotate 180 degrees (half a circle) when it is cocked.
2: Hammer Gun 536: Works the same as Hammer Gun 153, but uses a ratchet mech instead of a true block trigger.
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    Now you have to look down 2 comments
    I AGREE WITH PRODO! look down one comment!
    you could technically make a 4-shot burst gun with a mech like this.
     I used the system in my magnum concept thingy
    I just took a look at yours and it's similar, but my setups get more than double the range of motion so will be more powerful.
    I've made a similar gun to the ratchet mech one, but it wasn't powerful...
    im confused is the concept like a swinging lever witch hits a rod or what
    The large lever cocks it, the small lever hits the bullet.
     I made a true hammer revolver, it used the BR8 barrel, because all you need to do is push it.
