New Knex Concepts Notification #4 by Oblivitus
Check out the latest items.
Guns
22F14: High Power Pump Action Revolver: A pump action that cocks a firing pin near the back of the gun with a string spun 180 degrees backwards then forwards again by two wheels. This design would be very efficient and therefore make the gun more powerful because it would eliminate bending that normally occurs in knex pump actions.
23F15: MG 210: This one works just like a baseball launcher. A full auto powered by motors located in the box labelled A. Box A will also house several gears that will be sequenced to increase speed. Large external gears or wheels will fire rounds as they drop between the gears. The magazine is gravity fed. The trigger will stop the rounds from falling out of the mag when released, and drop rounds into the firing mech while pulled.
24F15: MG 210: This drawing shows the rounds being fired by the counter spinning gears.
25F15: MG 210: This drawing shows how the trigger works by stopping rounds from falling into the firing mech.
Miscellaneous Weapon Designs
8G6: Power Adjuster: A ratchet controlled by a hand crank used to tighten the firing elastics after the firing pin has been cocked to increase the guns power. There would also need to be a ratchet release.
Ammo Feeding
9A8: Tilted Horizontal Mag: Rounds would be pushed along by an angled mag pusher. This design saves space and therefore increases capacity.
1-40 of 76Next »
~KnexBuild~ says: Jan 17, 2012. 12:17 PM
I am making a gun with a tilted horizontal mag. On my design,
there is a lever which pushes the bullet up into the chamber,
making it like a bolt action with minimal friction.
DELETED_Haon says: Feb 22, 2010. 3:53 PM
(removed by author or community request)
~Aeronous~ says: Mar 2, 2010. 10:05 PM
 zOMG! your handwriting is the same as mine!
DELETED_Haon says: Mar 3, 2010. 5:53 PM
~Aeronous~ says: Mar 7, 2010. 1:51 PM
hmmmm. I tried making that mech, but it needs to force it back to lock in place, so the trigger gets in the way of teh lever.
RMConstruction says: Mar 2, 2010. 8:06 AM
Lever action? You're too late. i've already constructed a true lever action, that works. check my video...
DELETED_Haon says: Mar 2, 2010. 6:47 PM
 no you should he is being cocky.
~Aeronous~ says: Mar 2, 2010. 10:08 PM
 gah! what with the third picture, it looks rather wrong.
Der Bradly says: Feb 16, 2010. 11:55 AM
Not new.
DJ Radio says: Feb 16, 2010. 4:03 PM
I've never seen the power adjuster done on a gun before.
Der Bradly says: Feb 23, 2010. 10:10 PM
And none of us will.
DJ Radio says: Feb 24, 2010. 1:16 PM
I'll try something like that later on... How about that?
Der Bradly says: Feb 24, 2010. 8:39 PM
Well good luck.
KnexFreek says: Feb 16, 2010. 3:40 PM
Not nice.
haha Jk :)
Also DGM, you seen my guns? i think you would be impressed.
Der Bradly says: Feb 23, 2010. 10:08 PM
Nice is best to be put aside in some situations.
Oblivitus (author) says: Feb 16, 2010. 2:43 PM
The last two are.
DELETED_Haon says: Feb 22, 2010. 4:02 PM
MotaBoi says: Feb 24, 2010. 5:23 AM
still, my comment was mad over a month before yours.
DELETED_Haon says: Feb 24, 2010. 4:45 PM
MotaBoi says: Feb 24, 2010. 6:32 PM
 lol ohkay
travw says: Feb 18, 2010. 9:16 PM
LOL, third picture looks kinda dirty.
Oblivitus (author) says: Feb 20, 2010. 6:19 PM
You're the second person to say that. -_-
travw says: Feb 22, 2010. 5:39 PM
Oops. =P
Still, it does.
silentassasin21 says: Feb 21, 2010. 6:50 PM
HAHA :D
TheChemiker says: Feb 19, 2010. 4:27 PM
lol
TigerNod says: Feb 20, 2010. 11:37 AM
I like the pump action idea; it's simple, and it would surely increase ranges. Pumps rule!
The baseball launcher however... I don't think it would work. But there is only one way to find out...
Oblivitus (author) says: Feb 20, 2010. 6:20 PM
Take a look at Mepain's links.
TigerNod says: Feb 21, 2010. 2:51 AM
Ah, I see.
Mepain says: Feb 16, 2010. 1:34 PM
DJ Radio says: Feb 16, 2010. 4:02 PM
What was the range of the second?
Mepain says: Feb 19, 2010. 3:13 PM
Not far enough to be bothered.
KnexFreek says: Feb 16, 2010. 3:38 PM
PLEASE REPLY.
How far did the yellow rods go? 10 feet? 20? more? Please tell.
Very much appreciated.
Oblivitus (author) says: Feb 16, 2010. 2:36 PM
Oh, thanks for posting those, I didn't know about them. There still seems to be room for improvement on your versions though. The shotgun was messy and could be updated with a newer mag and the mg didn't have a mag or trigger.
DJ Radio says: Feb 16, 2010. 4:24 PM
He made that shotgun with a 50 round hopper.  And it was built in 2007.  I have no comment for the MG.
Oblivitus (author) says: Feb 17, 2010. 2:15 PM
A BR-18 revolver would be better.
DJ Radio says: Feb 17, 2010. 2:32 PM
You do realize that gun was made long before the BR's right?
Oblivitus (author) says: Feb 17, 2010. 2:46 PM
Of course,
take another look at my comment above;
"The shotgun was messy and could be updated with a newer mag"
noobererer says: Feb 18, 2010. 6:53 AM
Nice Ideas! They are all definitely possible. Has anyone done the horizontal angled mag yet? If not I will give an attempt...
Oblivitus (author) says: Feb 18, 2010. 8:53 AM
Thanks, no one has posted it before. Go for it.
1-40 of 76Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
