Introduction: New Knex Concepts Update #5
Picture of New Knex Concepts Update #5
1-5: Quad Barrel Shotgun: F16: A shotgun that uses a primary and secondary pin to fire 4 rods. The primary pin strikes the secondary which is confined to a small space at the front of the gun and behind the quadruple barrel. The images are color coded for ease of part identification. -by Oblivitus
https://www.instructables.com/id/Knex-Concepts/step6/Guns/
DJ Radio (author)2010-05-24
So you mean a larger scale version of something like Zak's NAR?
lphillips094 (author)DJ Radio2011-07-06
zak didnt make the nar
Oblivitus (author)DJ Radio2010-05-25
I don't know what that is.
DJ Radio (author)Oblivitus2010-05-25
Go look it up.
I couldn't find it, I'm not familiar with how to find specific guns on KI.
It's on Youtube.
Oblivitus (author)DJ Radio2010-05-26
I found it, it's a single shot? What does that have to do with this?
DJ Radio (author)Oblivitus2010-05-26
If you mod it, it can fire more than 1 round simultaneously, which is basically what you wanted to do.
barrax (author)Oblivitus2010-05-25
not a rectangle
Perfect Duck (author)2010-05-29
I once created a pseudo-shotgun that was effectively four block-trigger weapons combined as one unit. The four pins were pulled simultaneously with one pulling mechaism (a square with a handle) and then they four shots were also fired simultaneously by a fused trigger system.
It was terribly unreliable and not worth building, hence why I never posted it.
GrandeSwag (author)2010-05-26
 The shotgun idea won't work well. I made an identical gun many months ago. The two energy transfers cause the gun to lose a lot of power.
Oblivitus (author)GrandeSwag2010-05-26
That's what I was afraid of. Thanks for the heads up.
GrandeSwag (author)Oblivitus2010-05-26
 No problem.
erikos kostarikos (author)2010-05-25
 Oh nevermind I've already got it.
You put a bullet in each barrel, pull the trigger and the ram rams the red circle.
This bounces out the bullets right?
Correct.
 Yay!XD
KNEXFRANTIC (author)2010-05-25
ok but alothiugh its a concept it would be a muzzle load witch is the only problem i can see
 Is this somthing like a gun with 4 barrels?
I don't get it...
Fred the Penguin (author)2010-05-25
hmmm interesting.
MegaMetal8 (author)2010-05-24
Good idea
About This Instructable
1,009views
0favorites
License:
Bio: I paint, write music, and used to build knex guns. I have a Bachelor's Degree in Studio Art. - updated 5/7/2014
More by Oblivitus:Z3 Knex Gun (3-Barreled Semi-Auto Pump Action Revolver)Z3 Knex GunZ3 Knex Gun Firing Demonstration
Add instructable to:
