New Knex Concepts Update #5 by Oblivitus
1-5: Quad Barrel Shotgun: F16: A shotgun that uses a primary and secondary pin to fire 4 rods. The primary pin strikes the secondary which is confined to a small space at the front of the gun and behind the quadruple barrel. The images are color coded for ease of part identification. -by Oblivitus
http://www.instructables.com/id/Knex-Concepts/step6/Guns/
DJ Radio says: May 24, 2010. 8:18 PM
So you mean a larger scale version of something like Zak's NAR?
lphillips094 says: Jul 6, 2011. 8:44 AM
zak didnt make the nar
Oblivitus (author) says: May 25, 2010. 6:32 AM
I don't know what that is.
DJ Radio says: May 25, 2010. 11:57 AM
Go look it up.
Oblivitus (author) says: May 25, 2010. 2:02 PM
I couldn't find it, I'm not familiar with how to find specific guns on KI.
DJ Radio says: May 25, 2010. 4:25 PM
It's on Youtube.
Oblivitus (author) says: May 26, 2010. 3:14 PM
I found it, it's a single shot? What does that have to do with this?
DJ Radio says: May 26, 2010. 3:20 PM
If you mod it, it can fire more than 1 round simultaneously, which is basically what you wanted to do.
barrax says: May 25, 2010. 8:08 AM
not a rectangle
Perfect Duck says: May 29, 2010. 5:54 PM
I once created a pseudo-shotgun that was effectively four block-trigger weapons combined as one unit. The four pins were pulled simultaneously with one pulling mechaism (a square with a handle) and then they four shots were also fired simultaneously by a fused trigger system.
It was terribly unreliable and not worth building, hence why I never posted it.
GrandeSwag says: May 26, 2010. 2:25 PM
 The shotgun idea won't work well. I made an identical gun many months ago. The two energy transfers cause the gun to lose a lot of power.
Oblivitus (author) says: May 26, 2010. 3:01 PM
That's what I was afraid of. Thanks for the heads up.
GrandeSwag says: May 26, 2010. 3:02 PM
 No problem.
erikos kostarikos says: May 25, 2010. 9:20 AM
 Oh nevermind I've already got it.
You put a bullet in each barrel, pull the trigger and the ram rams the red circle.
This bounces out the bullets right?
Oblivitus (author) says: May 25, 2010. 9:27 AM
Correct.
erikos kostarikos says: May 26, 2010. 10:41 AM
 Yay!XD
KNEXFRANTIC says: May 25, 2010. 10:39 AM
ok but alothiugh its a concept it would be a muzzle load witch is the only problem i can see
erikos kostarikos says: May 25, 2010. 9:18 AM
 Is this somthing like a gun with 4 barrels?
I don't get it...
Fred the Penguin says: May 25, 2010. 1:59 AM
hmmm interesting.
MegaMetal8 says: May 24, 2010. 11:27 PM
Good idea
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
