3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
New antenna for Sony Ericsson GC83 wireless network card
Make a new antenna to replace the one I'm sure you have broken off inside your card. This one will not break and does not cost $30. Sorry about the crappy pictures.
Step 1Remove and disassemble card
Take to card out of your laptop and remove the SIM card. Use a small screwdriver to release the metal tabs along the sides and take both of the metal covers off. You may have to pry the tabs out of the sides of the socket, carefully.
3 comments
Apr 30, 2006. 5:01 AMvgid says:
BE CAREFUL... I think the antenna has to be resonant (cut to a specific lenght)... Its been awhile since Ive messed with radio but I think you have to cut the antenna to a specific lenght or you may damage the transmitter (I am assuming the device uses the antenna for transmitting)....
Apr 29, 2006. 12:40 PMjstech says:
It'll work better if you cut the ground side shorter than the antenna side (which would be the center pin). This is because putting the two right next to each other means they both receive (almost) the exact same signal, and so cancel each other out. If you want to get really fancy, you can find antenna designs on the internet. At 2.4 GHz, a wavelength is 12.5 cm.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Caferacer
