New K'nex Magazine
634
Published
Introduction: New K'nex Magazine
About: Man... it's been long since I visited this site
Hello people! I hereby present you my new K'nex magazine. It is just a millimeter smaller than the oh so famous mag which is used on almost every replica, the con-white rod-con magazine. This magazine has the exact same bullet, is capable of shooting white rods and dark grey cons with green rods. So what is the improvement you ask? Well, you remember these magazines with huge mag pushers sticking out? As if you didn't noticed yet, they're not exactly 'realistic' Since these mags are too small to be pushed by a bendy. I developed this magazine with an internal pusher. The straight magazine can hold 13 bullets and more or less if you lenghten or shorten it. you can make it curved too, for looks. I NOW ASK YOU TO REPLACE YOUR REPLICA MAGAZINE WITH THIS. This was Knex'X. Buy this gun at ammonatiln today! (Sorry Beanieostrich)
Step 1:
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    20 Comments
    So this does require a rubber band, right? I know this is the classic n00b question, but how would you but the rubberband on?
    do u think this could be implemented on my sniper, without adiing layers? could you make a removable mag that uses blue rods, thanks
    A 3-layer gun with a removable magazine is very hard to make, leaving alone reliability.
    Just get used to making 5-layer guns, everybody appreciates these more than 3-layers.
    Ziet er goed uit. Waaraan wordt hij ergens in het geweer gehouden? Dat is mijn probleem altijd met uitneembare magazijnen
    Natuurlijk moet je de bovenste witte staafjes aan de uiteinden breken zodat je hem in de mag well kan plaatsen. Vervolgens blijft hij in plaats door frictie van tape ofzo of door een magazine release.
    Okay. Ik heb ong. 10 gebroken witte staafjes. Maar de mag release faalt bij mij altijd met verwijderbare, kogelhoudende magazijnen. Maar ik zal kijken, op een volgend iets, of dat met dit magazijn wel lukt
    je bouwt zulke goede dingen, en toch weet je het niet? oke, kijk eens bij de
    BAW van Thedunkis, en zoek gewoon wat geweren op van mensen als Rec0n,
    Barrax en alle andere mensen die veel verwijderbare magazijnen gebruik(t)en
    Ik heb zelf maar 4 gebroken staafjes, maar toch lukt het me vaak. Als je een groot, dik geweer hebt (niet in de breedte maar van boven naar beneden) kan je een grote mag well gebruiken en wat tape op je magazijn zetten om hem vast te houden, hij kan wat schuiven maar als je het goed doet niet.
    vet! maar maak je mag pusher korter zodat je magazijn meer kogels kan houden
    Thanks :D Ik heb het magazijn zelf wat verlengd (ziet er ook wat minder raar uit dan met die korte), maar ik zal de pusher korter maken (alhoewel ik niet veel ermee schiet)
    geweertermen klinken zo awkward in het nederlands lol, 'voeding' 'magazijn' enz.
    XD nu dat je het zegt, inderdaad haha!
    Ik zal eens naar de BAW en zo kijken. Bij de modellen hoef ik niet op de betrouwbaarheid van de 'voeding' van kogels te letten, dus kan ik er gewoon een blauw staafje in zetten, waar een oranje clip dan onder klikt als mag-release. Maar bedankt voor de tip :D
    I really like the way this looks! Does it use broken pieces because I can't find any?
    Mine doesn't. But if you make a magazine well, you can decide if you do or not.
    True, I'll give it a try to see how this works out.
    Thanks!
