3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Restoration - New life out of a busted 1930's radio conversion
Restoration - New life out of a busted 1930\
First of all let me point out that this $35.00 Western Royal console radio was broken, and in my assessment would cost more to repair than to convert into a classy good sounding radio.
I was at my local thrift store a few months ago and saw this radio, its case was not in too bad a shape, but when plugged in nothing happened. I talked them down to 35 bucks, and loaded it up. When I got it home and took the frame out of it, it was apparent that it had been on fire, and that most of the point to point soldered electronics were cooked. I then researched how much a fully functional one would be and perfect ones go for about 300.00 bucks.
So I decided to modernize it, but keep the old look, and make the old controls work a new radio. It needed a full make over and a revamp of everything. The original parts are the knobs, case, metal frame, dial and bezel.
After its conversion its an AM/FM radio with MP3 player, with Bose bookshelf speakers and 150 watts of power.
This instructable cannot cover all radio conversions for all models of radio's, but is a good starting point, its also a complicated build requiring you to think on your feet and come up with your own solutions, I will give you all the information I can.
On to parts and supplies:
Step 1Tools, Parts and Supplies needed
Tools:
Hammer
Screwdrivers
Soldering iron
solder
drill with bits
jig saw
sanding equipment (orbital sander recommended)
Oven
Parts:
Replacement AM/FM receiver (KLOSS model 1 used here)
Small Mono or Stereo amplifier (Pyle 160 watt used here)
Speaker(s) (Bose bookshelf speakers used here)
Speaker wire
scrap particle board 3/4" thick
Supplies:
sand paper (if your case is in good shape, 400 grit to 1000 grit)
Lexan sheet plastic (available at most hobby shops in 8x10 sheets)
Carpet glue
paint (some cases including mine had black or gold trim)
Varnish
Wood stain
wood filler
1/8" plywood to make cabinet back or paneling.
Balsa wood
epoxy (5min)
Knowledge of electronics, woodworking, and mechanical skills needed for this conversion.
24 comments
Feb 3, 2012. 1:44 PMindian741 says:
Awesome Project ,
I did kind of the same thing , slight diffrent .
Took a philips BX610A , picked it up @ a yard sale for 20 bucks
It was still working , so i kept the inside .
Bought 2 Bose 101's , small but very awesome speakers.
Bought a quality 2x25 watt amp for 120 bucks ,
Ipod dock @ the top and a build in power suppley
@ the back its just a plug and play system.
Urs looks brand new , awesome , but i like the old / worn look better
And it sounds like bose shut , Awesome !!!
Jan 21, 2012. 4:56 PMrobot797 says:
i was crying so hard when i saw that
MURDERER
YOU KILLED A RADIO
YOU KILLED HISTORY
but on the other hand nice work revurbishing
(what did you do with the tubes?)
Feb 2, 2012. 11:26 AMrobot797 says:
even if it is broken it is fixable
if they are fixed they can go on up to 50 years
now it onle can 10 max
Jan 20, 2012. 12:24 PMcincygeek says:
Great `ible! Add me to the list of those who are currently working on a similar project. Found the console on the curb at a neighboor's house on garbage day, so rescued it. I got the cabinet restored already, it came out looking really nice. The radio has all the tubes tested/replaced, and I'm halfway through the re-cap, but no luck yet. My plan B is to replace the guts as you did, I'll keep you updated. Would be interested to know what you did to replace the "magic eye", looks like you inserted an LED? Thanks for sharing!
Jan 20, 2012. 12:07 AMmutantferret says:
Well done. A very nice project for anyone who wants a vintage look but with modern electronics. I'm glad you said to do some research because some old radios could be valuable.
Your old new radio turned out great.
Jan 19, 2012. 12:32 PMServelan says:
We've been thinking of doing this very thing, and while my DH is expert at all things electronics, I will make sure he has this on hand when we start in on one so he has all your tips available, especially for the cabinet (oh, wait...the cabinet's my job). Beautiful work! Glad to see someone else appreciates these old radios like we do. : )
Jan 19, 2012. 6:21 AMSolidRaven says:
Nice project. I didn't actually think about doing it like that when I did something similar. I've  kept some parts of the old radio intact. The amplifier I wanted for the pre amplifier for the valve sound cause the characteristics are hard to replicate without DSP and I didn't feel like designing a DSP board for this. Did make a few modifications though.
Replaced the old power supply that doubles as heater with an efficient switch mode supply. This also reduced the weight and actually cleaned up the sound cause the oscillation that originated from the power supply is gone. Contrary to popular believe this does not affect the audio quality. The switching frequency of the supply was in a different range than any of the amplifiers so it was easy enough to filter it out.
Put in a new speaker with roughly the same characteristics cause the old one started to show aging.
Replaced the power amplifier stage with a D-class amplifier cause the old power stage was about as efficient as a hamster running in a wheel is at power generation.
FM tuner went as well cause its frequency setting was heavily temperature dependant (I was able to switch radio station by leaving the doors and windows open for a few minutes).
Though cause most of the parts were somewhat of my own design it did fit quite well. If anybody needs help doing something similar to what I did feel free to contact me and I'll see if I can find a bit of time to help :)
Jan 19, 2012. 11:43 AMSolidRaven says:
Too bad, what was wrong with it?
Jan 19, 2012. 12:06 PMSolidRaven says:
Yeah, that tends to go badly with valve amplifiers.
Jan 18, 2012. 8:51 PMTopcat2021 says:
That is a beautiful radio and a wonderful job you did on the restoration/modification.
I would love to do something like this but I don't have a radio that size, I have 2 old tube style radios (table top models) with the Bakelite cases but I don't want to modify them as they both work (all original parts) they don't get used except as conversation pieces. I have been looking for years for a nice older radio like you found and I may find one someday.
Again wonderful job and very clever solutions to the problems encountered.
I wish you many years of enjoyment
Dan
Jan 18, 2012. 1:54 PMskittlespider says:
I have a similar project in mind to do someday. Last year I was helping clean out an abandoned building and I found a nice looking 8-track player. I don't know if it works or not. (The power cord has been cut for some reason).
Originally I thought it would be an awesome custom PC case. Now I might update the interior parts instead. Thanks for the inspiration!
Jan 18, 2012. 12:39 PMJKPieGuy says:
You should be careful cause allot of old electronics usually contain "Asbestos" and you kinda did a chinky job on the back, but I really like how you restored an old radio and all that and other than that you did a really good job.
Jan 18, 2012. 12:50 PMkenbob says:
Love this. I have this old radio and you got me thinking..... will post if if rebuild.
Jan 18, 2012. 2:12 PMTreasure Tabby says:
What a beautiful find. Not to mention a clever remake.
I have, well rather my parents have this old box style wooden stereo with prop up lid probably some time from the 70's. It has a record player, places to hook up mic’s and of course an a track player. The stereo part works great. I even hooked up a video game system up a few times for the sound.
Maybe it might end up in a similar manner. ;)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
60
Author:nickademuss
A+ certified with a degree in electronics engineering, and professional photographer using Nikon digital and film cameras for many years.
