New take on the Terra Cotta smoker
This is based on the Alton Brown (Good Eats is my favorite cooking show!) Terra Cotta smoker featured in the Good East episode "Q". I have found several sites featuring variations on this simple smoker. So I thought I would share my high-tech approach. Unfortunately, I don't have the steps it took to make the final product, only the finished components.
Step 1The history
I have actually made a terra cotta smoker before. It was just like the one Alton Brown made on his show. It worked well enough, but it was difficult to control at first. I only used this one a few times before it found its way to the attic. Fast forward a few years and I found myself wanting to get it back out. I wanted to make it easier to control though. I googled "terra cotta smokers" and found several great sites. Most were the same design as Alton Brown's original. I remember seeing one that stood apart though; it had an external control. That was it. Just the thing to make temperature control easier!
9 comments
Feb 26, 2010. 2:54 AMdeirhntr_1999 says:
Great job on the diagram, if you could, which relay contact did you use for controlling the heating element? Alarm 1, Alarm 2, or the control relay? You did refference that the realy was normaly closed until it hit the set point, so in theory, that leaves either the control relay, or the alam contact that is normaly closed...could you please clearify?
Secondly, what type of wire did you yse to connect the thermocouple "socket" to the temperature controller? Did you use "scrap" wire or was it the same wire type that is used for the thermocouple?
Thank you for your time.
Aug 8, 2009. 10:06 AMgrantbd says:
This is awesome. I modified my smoker to use a dimmer switch so that the hot plate used a varying amount of power to stay at a steady temperature instead of either being full blast on or not. Is there anyway you could include a more detailed parts list? I don't have much electronics stuff just laying around home here. Details like the temp sensor, the relay, switches, boxes that kind of stuff would be very helpful. Thanks!
Aug 14, 2009. 10:16 PMgrantbd says:
Thanks for your help with this, it definitely showed me the right pieces to use and will help me search for less expensive items on eBay. Just finding all the parts is half the fun! Also now I know which websites to look at for this stuff.
Jul 15, 2009. 4:52 PMEsmagamus says:
With all the gadgets, you forgot to put handles on it! :P
May 7, 2009. 10:59 AMtalonsblade says:
man i love this. however im not very electronically inclied. is there any info you can give on building the temperature control
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:echo2247
