iImage Information
This is based on the Alton Brown (Good Eats is my favorite cooking show!) Terra Cotta smoker featured in the Good East episode "Q". I have found several sites featuring variations on this simple smoker. So I thought I would share my high-tech approach. Unfortunately, I don't have the steps it took to make the final product, only the finished components.
Step 1The history
I have actually made a terra cotta smoker before. It was just like the one Alton Brown made on his show. It worked well enough, but it was difficult to control at first. I only used this one a few times before it found its way to the attic. Fast forward a few years and I found myself wanting to get it back out. I wanted to make it easier to control though. I googled "terra cotta smokers" and found several great sites. Most were the same design as Alton Brown's original. I remember
seeing one that stood apart though; it had an external control. That was it. Just the thing to make temperature control easier!
Secondly, what type of wire did you yse to connect the thermocouple "socket" to the temperature controller? Did you use "scrap" wire or was it the same wire type that is used for the thermocouple?
Thank you for your time.
Temperature Sensor (3871K55) - http://www.mcmaster.com/#thermocouple-probes/=36edyd
Thermocouple connectors (3869K25) - http://www.mcmaster.com/#thermocouple-jacks/=36efv7
Hi-amp power relay (7664K16) - http://www.mcmaster.com/#7664k16/=36ehu4
Omega:
Thermocouple jack (SJ-K-R) - http://www.omega.com/ppt/pptsc.asp?ref=RMJ_RSJ&Nav=temg13
Temperature Controller (CNI1633) - http://www.omega.com/toc_asp/frameset.html?book=Temperature&file=CNI16_Series
I bought the outlet, outlet covers, and heater plug at my local hardware store.
You can use any box available as your control box. Mine was scrap at work, so it was free to me, otherwise it runs about $120 from Hoffman - http://www.hoffmanonline.com/product_catalog/catalog_item_detail.aspx?cat_1=34&cat_2=2280&cat_3=78064&catIDs=78064,186&itemIDs=2934,5667&catalog_item=5667
The power switch is optional, you can just unplug it when finished! However, you can find several types from automationdirect.com - http://www.automationdirect.com/adc/Shopping/Catalog/Pushbuttons_-z-_Switches_-z-_Indicators
For those who don't want to go through the hassle of ordering and assembling all of the components, McMaster-Carr has a small single unit available (3313k21) - http://www.mcmaster.com/#3313k21/=36ew0c. Simply plug your hot plate in and put the probe in the top.
Hope this info helps! Thanks for checking out my instructable
