3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
New turret rifle.
New turret rifle.
just a good rifle
pros:
100+ foot range with finned ammo
 80 foot range with oodamo
new trigger
comfy handle
Looks Awesome! ( Acording to Visper123)
Both range tests where with two bands shot flat.
cons:
only 8 shots
generic stock
if 5 people ask to have it posted then i will
46 comments
1-40 of 46next »
Oct 11, 2010. 9:27 AMkrazyknexdude 32 says:
could you post instructions
Mar 31, 2010. 1:04 PMDJ Radio says:
Or we could just build the TR8.
Mar 31, 2010. 3:54 PMshadowninja31 says:
Or we could be productive and notice the be nice policy and say good job.
Apr 2, 2010. 6:32 AMThe Jamalam says:
Or we could notice that was in no way malicious and accept the constructive criticism: this is in no way new and innovative, a TR8 will perform just as well.
Apr 7, 2010. 5:48 AMThe Jamalam says:
Neither of which will affect the function of the gun. The trigger on the original worked fine, so why do you need a new one?
Apr 7, 2010. 2:35 PMThe Jamalam says:
Yes, but the TR8 default trigger blocks the ram at the ideal point. If it was any further back then the ram would have virtually no grip on the barrel and fail/bend. The hand can rest in pretty much a 90 degree range. Look at the M1 garand or the Springfield, a lot of guns like that have handles at about 10 degrees off horizontal. It doesn't affect it too much.
Apr 8, 2010. 12:18 PMThe Jamalam says:
What's the point in having an outstretched arm comfort when you have a stock? Or vice versa.
Apr 8, 2010. 1:05 PMThe Jamalam says:
See, the whole point I was making was constructive criticism. Even that, you can't take. I was suggesting that what you have done should be improved by more innovative design, but if you can't take it, that's fine.
Apr 8, 2010. 2:05 PMThe Jamalam says:
Erm. I believe I did tell you what was wrong with it.
Jun 3, 2010. 1:30 PMThe Jamalam says:
 I beleive I already did, as I have already said. Why resurrect an old argument?
Apr 2, 2010. 8:11 AMshadowninja31 says:
Or we could say we agree with you, but it's a good gun anyways.
Mar 31, 2010. 3:53 PMDJ Radio says:
1. You can extend the TR stock if you want.
2. I guess you're right there.
3. Do me a favor and measure the pin pull.  Pull the pin back and measure the exposed black rod, not the black rod that's in the gun or the connectors that connect to the black rod at the end of the pin, just the bare black rod.
Mar 31, 2010. 7:56 PMDJ Radio says:
1. I wouldn't really consider lengthening the stock a modification. You are basically making the gun fit to your preferences by extending the stock, which is objective.  Some prefer shorter stocks, some prefer longer stocks. The length doesn't improve anything in all reality.
2. Lets just discontinue #2.  From next comment on, #3 is #2.
3. I just measured my TR's pin pull.  It is also 6 inches.
Mar 31, 2010. 2:05 PMKnexFreek says:
 OR  if you just wanted to mess around and youve have already built a tr...
YOU SAY THIS ON EVERY TURRET GUN. JEEZ.
btw awesome job 5 stars!
Apr 8, 2010. 12:22 PMThe Jamalam says:
Dude, we say that on turret guns because they are exactly the same with a changed body.
Mar 30, 2010. 4:16 PM~Aeronous~ says:
POST POST POST! in the 'PROS' section, you forgot to say
Looks Awsome!
Pin guide!
slide action (kinda) easily made like that with a small mod.!
Mar 31, 2010. 4:00 PM~Aeronous~ says:
its simple, if you look at how when you pull it back, the yellow con with the duct tape around it, put another yellow con infront of it, except make it so it goes through the hole in the middle, leaving it friction frree. I can show you on skype if you are confused.
Apr 1, 2010. 5:06 PM~Aeronous~ says:
no worries! you could probably also fit the TR18 turret onto this!
the instructions are on Hiyadudes account. just make the turret and put it on this!
Apr 2, 2010. 3:53 PM~Aeronous~ says:
so are you going to?
Apr 3, 2010. 4:49 PM~Aeronous~ says:
good! cant wait! I built my version of this, it has a pin guide aswell, so I can't wait to build this one.
Apr 5, 2010. 11:36 PM~Aeronous~ says:
 oh, my one is 3 connectors thick. this one will definitely be much better, but does it have an auto turner?
Apr 6, 2010. 10:58 PM~Aeronous~ says:
 goody!
1-40 of 46next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:182515(Playzilla.co.cc)
Your probably thinking that im nuts liking math but i like the challenge and i have a REALLY mathematical mind with almost no imagination so i like something that is concrete and that i know will be t...
more »
