New way of making a ferrofluid. Costs less than 3$!!!
  • last photo ←
Ferrofluid - a substance that's liquid under normal conditions, but turns solid in the presence of a magnetic field.
I found new way of making home made ferrofluid and I want to share it with you guys.
The advantage of my project is cost. It's way cheaper than all other methods online and it is indeed very simple.
My ferrofluid consist only two inexpensive parts, you only need old record tapes and a bottle of acetone!
Step 1Materials
Materials
You will only need ACETONE, record TAPES, cooking OIL and MAGNET.
---500ml/16 fl. oz. Acetone. (1.50$)---
Acetone is high flameable be careful with it. You can get it at department store. It cost around 2$.
---10 music tapes or 4 video tapes. (0.00$)---
Use old music or video records tapes.You can get them virtually in any basement...
---5ml/0.2 fl. oz. Cooking oil. (0.00$)---
Every house has a secret room...The Kitchen...
---1 big strong magnet. (0.50$)---
You can get it from any old speaker in your house. Just take it apart and use it!
WARNING: IT IS VERY SIMPLE!
REAL WARNING: ACETONE IS HIGH FLAMEABLE AND NOISOME! BE CAREFUL WITH IT!
205 comments
1-40 of 205next »
Nov 20, 2011. 6:38 PMmagnet18 says:
most rust is actually fe2o3, dosen't change anything, just sayin...
Apr 8, 2008. 8:27 PM-Aj- says:
good idea, greae use for all those dead floppy disks and cassette tapes! can also use mentholated spirits. should work. it is abit less evil on your head + less flammable. also dissolves in water dont know if acetone does if that helps at all. im off to pilfer old video tape now!
Dec 10, 2010. 9:14 AMjoachimboaz says:
Acetone seems to have failed to dissolve video tapes for me. Did 'mentholated spirits' work for you? If so, what are they and where can I get them? Thanks.
Aug 28, 2011. 9:59 AMpsycho_3852 says:
READ BEFORE YOU POST, plz
Aug 13, 2011. 5:59 AMKevinAlien26 says:
At your local bar xD
Apr 3, 2011. 3:39 PMmrmorose says:
Great idea, but it doesn't seem to work very will with VHS tapes (no clue why). We couldn't get the ferric oxide to separate from the film using acetone set for about two hours. shrug*
Aug 24, 2011. 5:32 PMtomorrowsman says:
Same problem; audio cassettes worked fine, but I have a bucket of videotapes I could seemingly just respool and watch again. Anyone know how to do this with VHS tapes?
Mar 3, 2009. 6:31 AMr-philp says:
I tried dissolving the iron oxide off a video tape with acetone, but it did not work. Is the manufacturing process of video tapes different than audio tapes?
Dec 10, 2010. 9:10 AMjoachimboaz says:
Same problem. I don't know if they're chrome-based vid tapes or not. They look old, standard, and cheap. I found a bunch on the street, bought a gallon of acetone, let it soak over nigh, and nothing!. ALso, wasn't clear from your instructions: Do you let the acetone evaporate before trying to harvest your ferric powder? (Not that I had anything to harvest.)
I put a lot of time and effort into this and I don't want to give up. Could it be that the room temperature wasn't warm enough? Will waiting longer help? Or do I just have to throw away the whole ugly, stinking mess?
Aug 12, 2011. 5:31 PMjarheadwithm16 says:
Try using toluene.
Aug 12, 2011. 4:55 PMdeath192333 says:
Just spit balling here, but wouldn't used hand warmers work? They use iron powder that then oxides and produces heat. Thus spent ones contain mainly iron oxide with a small amount of impurities.
Aug 12, 2011. 3:46 PMkretzlord says:
I made similar stuff with silicon oil and some magnetic powder that came with a laser printer service kit, its called developer. Worked out pretty cool, was able to get some nice effects. best of all, no acetone required
Jun 10, 2011. 1:47 PMturbosinaboy says:
Have someone tried other than edible oil? Like motor oil...
Jun 2, 2011. 1:21 PMmr.squeakers says:
thank you
Jan 31, 2011. 8:20 AMFrankiescou says:
How much Fe304 Do you need for 1 ml? I need a bigger amount of ferrofluid and its for my science fair project.
Please Reply. (I got tons of Fe304 and vegetable oil).
Dec 18, 2010. 9:50 AMNicola Tesla says:
can u use nail polish remover?
Jan 25, 2011. 8:14 AMFrankiescou says:
Nail polish is the same than acetone but I think that it is better to find "acetone".
You could try... :D
Mar 4, 2008. 6:20 PMYummyPancakes says:
I would highly suggest working on your English. I had a lot of trouble reading this Instructable, and many of your others. Thanks.
Sep 20, 2010. 3:21 PMPikminRed says:
Aww Come on man! I read it just fine. Are you some other nationality? Because your first language is obviously not English. i grew up speaking English and Spanish. Its just fine.
Mar 22, 2008. 9:27 PMschimmi says:
it's fine
Aug 22, 2010. 8:00 PMmiiwii3 says:
i agree
Sep 18, 2010. 12:51 PMbudabob07 says:
good way to do it (pretty) easily, but for higher quality fluid you might want to try http://chemistry.about.com/od/demonstrationsexperiments/ss/liquidmagnet.htm
May 31, 2010. 3:33 PM123456 says:
Hey, I highly suggest not to use video cassettes, because there's a high probability that it won't dissolve and you'll just waste acetone. Audio tapes are the way to go.
May 31, 2010. 9:07 AMpiestas says:
A kodel uzdengt reik bliuda su acetonu? kaip nuo to gali but efektas geresnis ?.
May 10, 2010. 7:48 AMnutsandbolts_64 says:
 I guess I'm making another instructable about making ferro fluid for cheap. It involves sand, a magnet, and a plastic bag.
May 10, 2010. 6:52 PMnutsandbolts_64 says:
 Really! Where?
Mar 22, 2010. 1:44 PMwolf1234link says:
 what if you just pour it out is it like mercury like stays in single drops or is it like water and just flows away
Jun 22, 2007. 9:31 AMDarmago says:
Could you be a little more specific on how you "magnetize" the ferrofluid, I'm a little confused at this point. Also, why does size matter and not strength for magnetizing it?
Jul 11, 2008. 5:16 AMlast_decoy says:
another good substance is to ask mates or uni ("borrow") finished toner cartridges! there is still always at leased a table spoon of toner powder left in them!! (toner is a magnetic ink) mix this into the substance too. it adds to the effect really well. !! dont make it too weak cause it just flops about after the magnet then !!
Mar 19, 2010. 2:11 AMbeehard44 says:
i didn't know that regular toner cartriges use magnetic ink a.k.a. toner...
i thought that a special toner is used for that one...
Jun 27, 2008. 3:12 PMitsthatsguy says:
ok the way he made the ferrofluid is by putting amagnet underneath thats what he means by "magnatize" and you do want a strong magnet but you also want one that covers a big surface area so you get a big affect Cheers
Dec 7, 2008. 10:50 PMNewty says:
This does look easy. But I'm not sure I'd call $200 per cup a "very low price" when a $60 per cup result tops a Google search for "buy ferrofluid". Does this instructable produce better quality stuff? To whatnot: The dish soap is the surfactant and also emulsifies the oil and water. Apparently you can make magnetite more soluble in oil or kerosene using oleic acid, or more soluble in water with citric acid. I'm also reading a journal abstract here where they got crazy and dissolved in water particles made of magnetite+styrofoam, coated with oleic acid, surrounded by oil, coated with dodecyl sulfate.
Mar 19, 2010. 2:09 AMbeehard44 says:
yes, it is cheap, but you forgot onne thing, Delivery price. Maybe it is no big deal if you live in the US, but change the setting to the philippines, it's a different story...
Jul 27, 2009. 12:59 PMGlueyMcGee says:
just burn steel wool, you'll get more in a shorter period of time. Burning steel wool gives Fe3O4 or black iron oxide or magnetite.
Sep 24, 2009. 3:17 AMLance Mt. says:
Anyone else tried this? How safe? (the burning method)
1-40 of 205next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:Zujus
